Yes, totally agree. Since I now have a new headphone amp and haven't tried grounding the chassis, it may throw up some surprises. Obviously I will change the server's signal ground to chassis also.I don't want to speak for Andrew but I do believe it's very system dependent. I know Andrew will say you NEVER mix signal with chassis grounding, it's either one or the other. In my system I found signal grounding to work best.
ThanksHere is the retail price of the Zebrano 3
In US dollars it's just around $3100.
So just hooked up the Puritan Route Master and City Master. The RCA cheater is actually a ring that goes on the amp side of the RCA connection. I didn’t think that was considered part of the “signal path” but I guess it is. I’ll report back after 20-30 hours of use.I plan to implement the Puritan Route Master and Ground Master City.
My TW-Acustic amps only have 1 RCA connection.......from the Shindo preamp to mono amps.
Dealer suggested using an RCA cheater plug, but I'm concerned about to things:
1. Is it safe?
2. Won't I lose sound quality by not having a direct connection of my high-end Shindo Silver RCA interconnect?
Thanks for the advice.
As for the Puritan solution (signal not chassis grounding) I connected my preamp and mono amps to the Route Master and plugged the City Master into a separate dedicated outlet. The rest of my system is plugged into the Torus and that is plugged into a 2nd dedicated outlet.
Thank you for sharing your impressions on Puritan GM. I am also using combination of Entreq Silver Minimus and Acoustic Revive RGC-24K in my system. Impressive results from grounding!As promised, I am reporting back after using the Puritan Route Master and City Master for 20-30 hours.
First I need to note that after speaking with an Entreq dealer, I moved my Silver Minimus connection from preamp to safety ground on my Torus Power Conditioner. Very nice improvement with all the things Entreq does so well.
Now with the Puritan in place, here are my observations:
1. grip on the soundstage (20% improvement)
2. Blacker background (20% improvement)
3. Dynamics (20% I)
4. Pace and flow of the music (30% improvement)
5. Resembles a live performance (20% improvement)
6. Tighter more pronounced base (10% improvement)
7. Overall resolution especially noticeable on vocals (20% improvement)
I happen to really like Entreq in my system and I’ve heard a “maxed out” Nordost solution on a friends all digital system.
But I must say that for $900, I’m happy with the result. Also I can’t underestimate the impact of having “both” Puritan and Entreq connected.
Hope others may find this feedback useful.
