WestminsterLab Rei - Class A Amplifier
lscangus
179
195
175
38
Hello All!
I am pretty new to this forum.
This is a dedicated and official thread about the all new Rei amplifier from WestminsterLab.
The Rei is a brand new Class A mono-block produced by WestminsterLab and recently been awarded Editors Choice from Mono and Stereo.
You can read more about the review from the link below!
https://www.monoandstereo.com/2020/03/westminsterlab-rei-power-amplifiers.html
https://www.westminsterlab.com/rei
If you have any questions, post here and I will try to answer everything.
Specification of the Amp:
Power
100 watts @ 8?
200 watts @ 4?
400 watts @ 2?
Power ( Bridged )
400 watts @ 8?
800 watts @ 4?
Frequency Response
5 Hz to 40 kHz, ±0.1 dB
2Hz to 52 kHz, -1 dB
Distortion
(100 watts @ 8?)
<0.1% @ 1 kHz
Signal-to-Noise Ratio
104 dB, A-weighted
Input
1 balanced XLR input
Output
1 balanced XLR output
Input Impedance
200 k?
Output Impedance
0.018?
Dimensions
W232 x H112 x D320 mm
Weight
16KG
Each and every resistor in Rei are hand matched one by one to ensure the symmetric schematic of the Rei is as symmetric as possible. We meant it when we say we are obsessed with every single details.
#MadeInHongKong
The Rei Amplifier has also been selected to be M&S Best of 2019, together with a lot of other high end gears!
#madeinhongkong
Reactions: CKKeung
Very nice
Hello All!
Power
100 watts @ 8?
200 watts @ 4?
400 watts @ 2?
Power ( Bridged )
400 watts @ 8?
800 watts @ 4?
Frequency Response
Distortion
(100 watts @ 8?)
<0.1% @ 1 kHz
104 dB, A-weighted
Input
Output
Input Impedance
200 k?
Output Impedance
0.018?
Dimensions
Weight
16KG
very nice.
It is interesting how they rate the amp power output in stereo and mono/brdiged mode. This one has 100w/8 ohm in stereo and instead of doubling to 200 it mentions 400w/8 ohm on bridge mode. Little hard to understand.
On the other extreme, Gryphon essence mentions 50w/8 ohm in stereo and 55w/8 ohm mono.
Sometimes, it is not simple math.
Hello RachiK,
P=V^2 / R. So if the power supply, transistors and regulators are allowed, the Power will be x4 as the voltage doubles ( In bridged mode, the output voltage will be doubled ).
StereoSound Japan has done a listening test comparing a Single Pair / Dual Pair / Bridged config test. And it has been described by him ( a very experienced and senior critic in Japan ) Best 5 sound he has experienced in his life.
You can read more by following the link ( Google translate is available on top right corner )
StereoSound Rei and Quest Review
Hello RachiK,
Thanks for the insight.
Any dealers in US or way to demo them ?. Am interested in this especially after the mono and stereo review praised them so much.
Our potential distributor / ambassador of WestminsterLab will get theirs hands on their first complete kit very soon. We are targeting to launch the brand sometime in 2022. In the meantime you can read another review from Stereo Sound Japan. Describing the Rei as ( video with 8k resolution with ultra-high resolution lenses )
StereoSound with Rei
Reactions: FDPDK
How much will they cost in US ?
The MSRP for the Rei - Class A amplifier and the matching Quest - Preamplifier are 30k and 21k USD ( without options ) respectively.
The amp cost is for stereo or mono ? (The mono and stereo website mentions 30,000 per pair).
Hello RachiK,
Very nice amps.good luck with them.
Looking forward for these amps.
Looking for advice on pre-amps with the Rei. Currently I am running the Lumin X1 directly into the Rei. The Quest is cost prohibitive because of the weak yen. I can get the Accuphase C3900 at about 1/3 less than the Quest and was wondering if any one has had this combination and/or what other choices I can look into? Previously I was using the Luxman M900u/c900u combination. Speakers are Dali Epicon 6. Any advice is appreciated.
Hello RachiK,
Question for Angus or Gary: I just read this article and it certainly confirms what you fellows have been telling me about bridging the REIs. But why not simply offer a new version of the REI with double the power? Economy of scale with same sonic improvement?
