Emile, will the upcoming Taiko Battery have an option to power the switch too?
Absolutely yes!
2" height saves me as I'm out of shelves!...you mean the 9x9x2 block of heavy-quantum-dense-matter? 33 lb switch! Going for the world switch weight record! OMG.
I hope it’s not 9’ x 9’ x 2’ neitherI was wondering if those dimensions are correct! 9” x 9” x 2” - is that right?
If it is, then a solid block of steel that size would weigh only about 12 lbs more — that’s a solid block!
Maybe it’s not steelI was wondering if those dimensions are correct! 9” x 9” x 2” - is that right?
Maybe an alloy of magnauseum and unobtainium?Maybe it’s not steel![]()
Hello Emile (@Taiko Audio )The BMS we're working on casing options now, we have a few 2 box prototypes but we've also managed to fit everything into a single box, this is slightly larger at 483*483*185mm without footers (for reference, the current Extreme is 483*455*165mm) but otherwise will have more or less the same looks as the current Extreme, though with improved finish options. If we were to offer this option we would naturally accept a trade in of the old "chassis" which could then be stripped/refinished/repurposed.
Nice to have Emil posting again....
I think he missed us. Loved the flurry of messages today. Exciting times. Can't stop thinking of where I am going to fit this mini spaceship.
In your message number 12067 you mention the possibility of upgrading the current Extreme with the battery based power supply.
Will it be possible to power the new switch with the Extreme's internal battery based power supply?
In other words, do you think it would be feasible to include a power output at the back of the Extreme?
This would make it possible to have a compact system, consisting of two boxes: Extreme + Switch.
Cheers,
Thomas
@Taiko Audio That's great news !Yes that is exactly what we are planning to do.The prototype BPS on the attached photo below has 3 outputs.
So ideally with 3 outputs Extreme/Switch/Router? Very Intriguing...Yes that is exactly what we are planning to do.The prototype BPS in the photo below has 3 outputs.
Dear Emile and Edward,
This thread is now 615 pages long with more than 12k posts.
It's quite difficult to read through and locate specific info.
On #12067, we are happy to know that the new Origami chassis is ready and is a more affordable choice for Extreme customers.
It's mentioned that the coming optional BMS might be able to be put together with the server section into ONE Origami chassis.
Is this correct?
I would also like to know more about the new powersupply section/circuit boards which employs Gallium Nitride components (showed during the Munich Show in May).
Is it ready now or very soon?
Is this an option and can be offered to current Extreme Server owners as a powersupply upgrade?
If some Extreme owners don't want to install BMS, can this newer and better powersupply section be avaialble and installed without the battery section?
Can this new powersupply section be installed and replaced the old one inside the current CNC Extreme chassis?
Many thanks for your answers in advance!
So, if I understand correctly, the Extreme's internal power supply will provide :
- an output for the motherboard
- an output for the USB and Network cards ( using a y-shaped cable)
- An output to the outside (19V), which will be able to power the switch.
Is this correct?
1) Is it ready now or very soon? - I'd say a realistic launch will be in april-may 2023
2) Is this an option and can be offered to current Extreme Server owners as a powersupply upgrade? - Yes
3) If some Extreme owners don't want to install BMS, can this newer and better powersupply section be avaialble and installed without the battery section? - Possibly yes
4) Can this new powersupply section be installed and replaced the old one inside the current CNC Extreme chassis? - Possibly yes
