I am still thinking about starting simple and DIY, and affixing 2.5” Duro 70 Sorbothane hemispheres to the bottom corners of 2” thick walnut butcher block platforms.
The Duro-70 Sorbothane would have also worked quite well. The shear weight and density of the concrete is so massive a number of materials would have worked well. BTW this process is exactly as concrete countertops are made. After finishing and sealing they take on a very interesting patina. The long shelf I stained with coffee before sealing and it took on a copper hue.If I understand you correctly, the Mephisto is on a 4 inch platform of concrete with a half- inch cork sheet on the bottom of the concrete. And this platform sits on the floor.
Since the cork is a vibration absorbing material, why did you choose cork rather than, for example, a half-inch sheet of Duro 70 Sorbothane?
I don't see any reason why that wouldn't work extremely well...I am still thinking about starting simple and DIY, and affixing 2.5” Duro 70 Sorbothane hemispheres to the bottom corners of 2” thick walnut butcher block platforms.
I am looking at Butcher Block also. It there any reason you did not go with the round spring bottom they have?Ron, simple, easy and affordable. Butcher Block Acoustics in nearby Monterey Park offers a double solid maple or walnut platform shelf separated by a sheet of sorbothane They also offer beefy brass footer similar to the ones Mapenoll made famous. There is little question as to the efficacy of solid maple and brass. Add in the sorbathane and what a value!
Talk is cheap so I am ordering three for my listening room today - one for the Westminster Rei amplifiers, one for the Quest pre-amplifier and one for the LampizatOr Horizon DAC arriving soonThey will even make the stands to order for fit you big VTL monos!
link to platforms - https://butcherblockacoustics.com/collections/double-b-isolation-platform
Will look at end grain, a little more expensive but it really looks nice...BTW still waiting on DHL H is supposed to be here today. I would never ever use DHL if I had to ship, they are MORONIC!!I am looking at Butcher Block also. It there any reason you did not go with the round spring bottom they have?
Prior to my CMS racks every one of my components sat on 1.5" thick butcher block. Easy to source as I ordered from a local kitchen cabinet maker few miles from my house. I used maple BTW for the wood choiceI am looking at Butcher Block also. It there any reason you did not go with the round spring bottom they have?
I really like butcher block platforms from Butcher Block Acoustics, and I just rest them on cubical hardwood blocks onto the carpet; this provides good mechanical grounding. I then rest my component on HRS Nimbus Couplers and Spacers on top of the maple (or walnut) butcher block. https://photos.imageevent.com/puma_cat/stereopix/websize/Constellation-Tall2A.jpgI am still thinking about starting simple and DIY, and affixing 2.5” Duro 70 Sorbothane hemispheres to the bottom corners of 2” thick walnut butcher block platforms.
FWIW: I have a Mapleshade rack from when I was starting out. I also ordered some plinths, after which began a cascade of negative experiences.It's Mapleshade not
I just got off the phone with Butcher Block. Compared to other shipping sources I have found DHL to be the best even though that is not saying much. My Lucas Audio LDMS, Lampi Pacific, and Horizon all came early and without damage.Will look at end grain, a little more expensive but it really looks nice...BTW still waiting on DHL H is supposed to be here today. I would never ever use DHL if I had to ship, they are MORONIC!!
wellfloat-global.com
Some companies use concrete platforms for their demo to have a local huge impact of "earth mechanical ground". This work ! Concrete is rigid and has no sharp modes.Very interesting: I live in a log home so obviously lots of wood. I have heart of pine flooring(3/4" thick) throughout the home. Block/Concrete Columns for foundation throughout underneath. 6" thick log walls. Aesthetically we wanted to combine Wood/Metal/Stone. I've tried a number of applications for isolation, wood and metal. I'm a hands on person so I like to create. The best isolation in this style home is concrete platforms. Keep in mind the floor platforms weigh north of 250lbs. So this isn't a practical application. The Mephisto and Taiko are on separate floor platforms that are 29" X 23" X 4" thick with 1/2" cork adhered to the bottom. All other components sit on one 80" X 28" X 2" thick shelf. I had to get some farm workers to help set it (5 guys and myself) The large long shelf sits on custom brackets that are lagged into the 6" wall. No contact with the floor. I have a rubber material on the brackets for additional isolation. All components with the exception of the Mephisto all have isoacoustic component isolation. I never took a physics class in my life but it is truly amazing what proper isolation can do.
Hi Ron,Does anybody know what are the best concave dimpled coaster things to receive the foot spikes of the VTL Siegfried II? Are the holes in those coasters a standard size?
Microstrip, do you use those divot coaster things underneath the spikes of your Siegfried IIs?
