EMT is renewing itself
EMT 128 phono stage sounds as good as the looks but requires a relatively high output cartridge. it’s hard not to be impressed by the build quality when you open the top cover.
Great aesthetics at the least. That's a 9" arm on the new 928? I wonder if it can mount a 12". And if the phono stage is also battery-powered.
I'm guessing not on both questions.
Looks like the Thales Slim.
At this point EMT is simply a badge for Thales products. You’ll accept them if you like their house sound or hate them if you’re not a fan. Either way EMT exists no more. In a way it‘s been gone for decades.
david
Reactions: mtemur
The EMT 128 has a switchable Gain (64 and 70db), I had very good performance in using a Koetsu cartridge.
Reactions: mtemur
What’s the deal with those tubes? Soldered in and if you need replacement you undo that one bolt and get a new tube and daughter board from EMT?
probably yes. it’s not mine, a friend’s phono stage actually.
