Does the Funk have two subs? It's unclear but it would be good Gary points out for neutralizing self sound. They have WAY more power than the other ones, plenty to get it moving.
Servo isn't useful in the lowest frequencies. It doesn't do anything useful. It's good in the upper bass for sure but in the super depths it can't correct anything without overshoot. Any well programmed servo sub decreases the servo control as it goes into the 20's and 10's. Frankly almost all the sound coming out is second harmonic because the driver cone isn't big enough (and never will be).
I'd say power is more important than the cabinet when you're talking sub 20hz, at least for being sufficient of actual volume and not greatly reduced (which doesn't necessarily sound bad). Also important is thermal problems and the actual driver by Funk has serious thermal control which is necessary for continued play without loss of volume (especially with thousands of watts). The only one I know that goes farther maybe is by Pi.
Btw I know a few people who say the Funk is much better than Rythmik.
