Site Founder, Site Co-Owner, Administrator
I was kind of hoping for an XDMS feature on the TAS wannahave listIt would not be that hard to add a disk space free/usage feature to XDMS, placed on the wannahave list.
@Taiko,
this confuses me a bit.
even though the JLsounds may support 32 bit, the TotalDAC system it feeds does not and only supports 24 bit.
so why 32 bit?
Yes, a known function but I want to see how much is used/available on each drive in my Extreme..<Sound of hand slapping forehead>
Doh!
Why didn't I think of that? I do it all the time to see the free space of my Mac's internal drive, attached drives and NAS' and thumb drives.
The Mac "Get Info" function (File > Get Info > (highlighted Extreme "Music" folder on the Mac desktop) gives this result:
Couldn't be much easier and no VNC into the Extreme desktop required.
Tip of the hat to @dminches!
Steve Z
@Taiko,
so why 32 bit?
What do you mean by “each” drive? All the storage drives are combined into 1 array in a standard Extreme setup. Is yours different? There is a separate OS drive but I am not sure why one needs to know how much space is available there.
Yes his is different as a result of replacing 2TB with 8TB drives versus how much time we wanted to invest into storage migrations. Where before we had machines with 12 2TB drives for 24TB (4 or 8TB drives were not available in the first years of the Extremes life), we now more often have machines with 4 or 8TB drives for 32 or 64TB of internal storage (using 8 drives).
As different storage spaces volumes, but yes that is similar to logical drives.So his drives are defined as different logical devices?
Hi Emile, Could you please share good 8 TB drives that replace the 2TB?As different storage spaces volumes, but yes that is similar to logical drives.
So Emile would there be any sonic advantage to just have one Hypercard in my Extreme (adding 2 more 8TB drives to my current one) for a total of 32TB and eliminating the second Hypercard?
Unless I'm missing something shouldn't each volume show up on the network once you log into your Extreme from the Mac desktop (Finder Menu: Go > Connect To Server > (volume list)?Yes, a known function but I want to see how much is used/available on each drive in my Extreme..
Shows as one volume....
I thought all music is on drive D in the ExtremeIs it configured as one volume? In Roon do you have to select multiple drives for the system to pull in all your music?
