Me too. Do you know when are you expecting yours?I have not. I had a Masterpiece on order.
Looking forward to hearing your feedback after you got it.Me too. Do you know when are you expecting yours?
Do you mean the Constellation Mini?I had the opportunity yesterday to test the entry-level Pashanko server (powered by a good power supply) against my Antipodes EX in both USB and AES/EBU (using the Antipodes P2 reclocker) modes. The Pachanko came as a very clear winner; more quiet, better soundstage, timing and tonality. Peaks (like orchestral tutti) were navigated with ease by the Pachanko without any hint of strain. The P2 reclocker in AES/EBU mode improved on the USB output but was still well behind the Pachanko. I would definitely recommend a demo if you are in the market for a good Roon server.
The Constellation Masterpiece. I ended up speaking with Chan last night. The lead time is 8 weeks. Chan was very pleasant and helpful and willing to give me whatever time I needed with questions. Impressed!That’s right
Yes sirAh, well.
”DSD 512 and DSD 1024 only with Windows PC with installed driver or Linux PC with Kernel 4.4 or higher at USB”
Would the Constellation do that?
Oh how I love the T+A SD 3100 HV Dac. My final choice came down to the MSB and the T+A. The T+A was out of my budget at the time but oh how I love that unit.1 x AES-EBU 32...192 kHz / 16-24 Bit
6 x S/P-DIF:
2 x Standard Coax
2 x BNC 32...192 kHz / 16-24 Bit,
2 x optical TOS-Link 32...192 kHz / 16-24 Bit
2 x USB DAC:
Device-Mode max. 768 kSps (PCM) und DSD 1024*, unterstützt asynchrone Datenübertragung.
*DSD 512 und DSD 1024 nur von einem Windows PC mit installiertem Treiber oder von einem Linux PC mit Kernel 4.4 oder höher.
2 x USB Master-Mode für USB-Massenspeicher (Stick oder HDD)
2 x HDMI IN, 1 x HDMI OUT mit ARC
1 x IPA (LVDS)
thes are the input options of my T+A SD 3100 hv dac.
Which output would you config at a Pachanko Constellation to get the best results?
Cheers, Ulrich
That's impressive. What did you use for PS? What are the required specs for the Mini? The website didn't mention.That’s right
