Alsyvox - Hi end Munich 2022 - your thoughts
ariel2611
20
4
68
57
Haifa, Israel
Attached a photo i've took from the show...
I'll be glad to hear your thoughts, in my humble opinion, the Alsyvox with Omega Audio in 2019 - sounded far better..
An injudicious choice of power amplification it would appear.
I posted this over on the Munich thread but here it is again-
Alsyvox is normally shown with higher power at shows. At the upcoming NW show in Seattle, late July, we will be driving the Botticelli X with 600 Watts of Pilium SS power.
In the US the Alsyvox speakers are available for demonstration with both SS and tube high power.
This year Daniele decided to show how easy the Alsyvox are easy to drive, maybe not a statement type sound from Alsyvox but we have a lot of Alsyvox customers who fancy the idea of driving their Alsyvox speakers with low power.
I also like the Esoteric F03A ($15K) 30 Watt Class A integrated SS on the Botticelli X along with higher power SS or high power tubes.
The Alsyvox are VERY flexible when it comes to amplification choices.
+1
AFAIK, the new released Alsyvox has a sensitivity of 97dB which is top for this type of speaker.
Matt
Reactions: BillK
They had planned on using the JA80s for the show but for some logistical reason the JA30s became the only option. Again, the system wasnot set up as a end all statement system, but showed the speakers sensitivity for those that like low power amps.
As Emile said this pair of Raffaellos that were at the show will be on display at the Taiko headquarters for those that are interested in hearing them with more powerful amplifiers.
Reactions: BillK
From the Manufacturers website I read 94dB / Nominal 4 Ohms unless I am looking at the wrong model, may I enquire as to the minimum value at 20 KHz ?
From experience with my previous ML CLX’s ( Impedance Nominal: 6 ohms, Minimum: 0.7 ohms @ 20 kHz )driven by several disparate valve amplifiers over the years leaves me somewhat sceptical of the prudence of 30 Watt valve amplification, unless Jadis have invented a current driving 30 Watt monster.
From experience with my previous ML CLX’s, Impedance Nominal: 6 ohms, Minimum: 0.7 ohms @ 20 kHz driven by several disparate valve amplifiers over the years leaves me somewhat sceptical of the prudence of 30 Watt valve amplification, unless Jadis have invented a current driving 30 Watt monster.
Yes, you are looking at the wrong model. The Raffaello that premiered at the show is not yet listed on the site.
You don't have to use 30 Watt tube amps if you don't want to, BUT Daniele has done all of his development using a 30 Watt tube amp over the years for all of the Alsyvox models.
Most Alsyvox owners use amps with more power than the JA30's. If you read my comment in a post above I said the original intent was to use JA80s but they were not available due to logistical reasons.
Many people really liked the sound at the show with the JA30s, although Alsyvox has done MANY prior shows all with higher power amps. This was something different. A change of pace.
Reactions: BillK
I didn't judge which amp was better,
But it seems, the higher the amplification, the more of everything comes out from the speakers...
And yes, Alsyvox introduced some kind (as far as I guessed, I didn't got a clear answer) of a new Botticelli...
A lot of customers have smaller rooms than the room at Munich. They also don't have 20 people in their room. 30 Watts in a small room for someone that doesn't play at high volumes, which I have a LOT of customers that never play at higher volumes, is plenty of power to driver even the 94 db Alsyvox.
I would be careful about comparing a completely different tech speaker, ie, you CLX's, to an Alsyvox. Going by specifications alone will not tell the whole story.
A LOT of people prefer lower power amplifiers as they are more refined sounding to them. They enjoy lower power amplification. For these type of listeners Alsyvox is a definite option for them.
Reactions: BillK and mtemur
I agree I like higher power, both tubes and SS on Alsyvox, but some people like lower power amps. Depends on the person and Alsyvox is available for both types of people.
Not sure what you mean about a new Botticelli? There is no new Botticelli, just the Raffaello was shown and announced at Munich. Or am I missing something that you heard about the Botticelli???
Also in 2019, it was the four panel Caravaggios that were played with the SS amplification.
Thank you for the clarification regarding the model, may we know the Minimum ohms value at 20 KHz if that figure is available.
I would add that were I to ever consider ribbon transducers again that Alsyvox would be most certainly on my radar.
With the high frequencies the lowest dip is to a little under 4 ohms....around 3.8 or 3.9 ohms. Lower frequencies don't dip below 5.5ohms.
Look here:
97dB sensitivity
Matt
Reactions: Rhapsody
Well from a nominal 4 Ohms that would be quite remarkable! By way of disclosure I have also owned Apogee Duetta Signatures and lived with a friends Scintilla’s on extended loan.
Reactions: BillK and christoph
In the 80's I owned SiX pairs of Apogees. LOVED THEM.
Daniele the developer of Alsyvox also was an Apogee guy. He worked for the next 30 years to develop what we now have with Alsyvox.
For me, it was a dream come true. Full panel ribbons, magnets on both sides, which gives the efficiency, and easy to drive. Heaven for a full range ribbon lover like myself.
Sorry, Maybe I missed that announcement...I've asked the guy who demonstrated them, I didn't remember any "Raffaello" comes out from him..maybe a misunderstanding...
I see they had the Jadis integrated amplifier that uses the KT 170 tubes, was this not fired up as this would have been quite an interesting combo ?
Reactions: Zarir
The Raffaello was the speaker that was at Munich this last weekend driven with the Jadis JA30s. In 2019 it was the 4 panel Caravaggios at the Marriott driven with Omega.
Reactions: BillK
