I don’t care what they call it; I just want to hear it!
Patience little grasshopper. May is around the corner and Munich just as close so we have to be no more than a few weeks away. My hope is that we users have it before it is released at Munich which if so would suggest things are even closer for we lucky ones.I don’t care what they call it; I just want to hear it!
I don’t know. We are but mere WookiesI have all the patience in the world. Once the Christmas release date came and went (for good reason) I have been content with waiting it out.
Are they showcasing it at Munich or is it just a poster tease?
Pretty sure I heard it in Oldenzaal a couple weeks ago and it was stunning. No idea how it compares to its predecessor, but what I heard was truly exceptional.Patience little grasshopper. May is around the corner and Munich just as close so we have to be no more than a few weeks away. My hope is that we users have it before it is released at Munich which if so would suggest things are even closer for we lucky ones.
We can't confirm anything just yet but there is certainly every intention of showing more than just a poster tease.I have all the patience in the world. Once the Christmas release date came and went (for good reason) I have been content with waiting it out.
The Extreme did it's job for 3 days at Axpona. It fed an Esoteric DAC and the digital never glitched once in 3 days. Also mentioned in the TAS report as one of the BEST rooms at the show.
This is Greek to me. It doesn’t seem like I’d need anything other than Taiko sw (TAS or XDMS) to use an Extreme as a server feeding my DAC via USB? Where does Amanero and JLSounds and Roon come in?I can’t speak for Taiko but my Pacific came with Amanero and in order to derive full benefit of TAS I had to switch to JL Sounds I would have to think that the same would be required for XDMS. Not sure how we would run both Roon and XDMS simultaneously when the TAS app switches from ROON to TAS. I would imagine the same for XDMS Plus Roon will be history with me for sure. I haven’t used it in years
That's all you'd need. The discussion in Greek is a particular issue Lampizator DAC users have run into.This is Greek to me. It doesn’t seem like I’d need anything other than Taiko sw (TAS or XDMS) to use an Extreme as a server feeding my DAC via USB? Where does Amanero and JLSounds and Roon come in?
When I had my Pacific it came with Amanero board. When there was an update to the TAS software there were limitation issues wrt DSD and filters they used. Emile told me that Amanero had maxed out and users get full TAS with JL Sounds or equivalent YSB board. I changed to the JL Sounds USB board and never had a problem. My Horizon DAC uses JL Sounds. I think the issue is not the JL Sounds but rather AmaneroThis is Greek to me. It doesn’t seem like I’d need anything other than Taiko sw (TAS or XDMS) to use an Extreme as a server feeding my DAC via USB? Where does Amanero and JLSounds and Roon come in?
Steve,When I had my Pacific it came with Amanero board. When there was an update to the TAS software there were limitation issues wrt DSD and filters they used. Emile told me that Amanero had maxed out and users get full TAS with JL Sounds or equivalent YSB board. I changed to the JL Sounds USB board and never had a problem. My Horizon DAC uses JL Sounds. I think the issue is not the JL Sounds but rather Amanero
Thanks!That's all you'd need. The discussion in Greek is a particular issue Lampizator DAC users have run into.
Steve Z
It seems that the problem is Amanero and it’s limitations. AFAIK Emile has factored in virtually every DAC that is being used with the Extreme and has default settings for each so I doubt this is an issue for anyone any moreSteve,
Thanks. My Holo Audio May DAC does not use (or at least call out) a branded USB, et al board brands/types. I wasn’t aware that Lapizator does. Presumably as long as the Taiko Extreme sends “standard” USB data with either TAS or XDMS my DAC will work fine up to it’s limit of 512DSD.
This rabbit hole is deep and wide!
Evan
Thanks for explaining Steve.
The Amanero doesn’t allow for adjusting the buffer size if I remember correctly. JL Sound does. TAS exploited this feature for increased SQ. Will XDMS do the same? Seems likely.
This will be relevant to me as my Extreme will arrive in a couple weeks while I still have a Pacific with Amanero. In two months or so my Lampizator Horizon will arrive with the JL Sound card. So I’m likely to take a path covering all these bases. Roon, TAS, then XDMS; then onto the JL Sound with Horizon.
In the meantime I’m still curious if XDMS will be able to be used as the server library, or core, for the endpoint which is the source for my home zone system. Roon allows for one library on the server to front all devices. For those not familiar with this common arrangement of feeding an endpoint (player with renderer and dac) it works through the home LAN; not usb, spdif, etc.
