Trying to identify BW speakers.
mbyvr
4
1
3
51
Hello. i’m trying to identify this BW speaker. Is it great quality? from what year? potential value?
Thank you, mel
My hunch is, it's a B&W Matrix2 Series2 speaker. I think these were from the late 80's???
Reactions: mbyvr
Thank you. but i think these are the ones you’re referring to unless bw changed the legs (?)
No. The first image you provided reminded me of their Matrix series from the 80's so I googled it and found an image seamingly quite similar to your first image. If it turns out to be smaller bookshelf types my apologies.
But this link below is what led to my response to you.
Reactions: mbyvr
a matrix 2/2 have blue rings arround bass and tweeter. remove the fabric frame and look, or take a flashlight and shine it on the bass blue ring. if not blue no matrix
At that time the most complex speaker housing with very little internal nesting. Dimensions: 600 x 260 x 320 mm (H x W x D)please check
example 3/2 matrix internal master build
Reactions: mbyvr
Thank you.
i’ll peruse the link.
i’m a newbie in vintage gear
Thank you.
the person may give them to me or may not.
but if he gives them to me he can provide me with the model number.
i was just jumping the gun and finding out what they are
Reactions: DasguteOhr
