Hi Steve, before I purchase some valves I need to know the la and gm ,if they are under 90 percent than I will not buying them and that's the reason why I'm only have 3000 more valvesHi Adrian
of your 3000 tubes are most of them new in box What percent are new
Steve, it sounds like you are "casing" a joint.Hi Adrian
Enjoy !!!
There are no best tubes in the world as they're all system dependable , your Telefunken E88CC looks like Made by SiemensTwo of my favorite E88CC. The Philips tubes are really underrated, while the Telefunkens probably need no introduction.
That is the common wisdom, yes. The same goes with Telefunken D3a - apparently made by Siemens. However, in both cases, the Telefunkens sound different than those actually marked as Siemens. Go figure.There are no best tubes in the world as they're all system dependable , your Telefunken E88CC looks like Made by Siemens
