The latest version of Roon has a bug that appears during the import process. Here is the documentation:
“Importing causes one track to appear in another album of the same name. The album with the rest of the tracks contains duplicated track names (indented).”
Importing local album bug (from B911) -split tracks [Ticket in, fix pending]
The short-term fix:
“You can try to Edit the albums. Long click on one of the albums to select it, then select the other one, then click the three dots and select Edit. If you are lucky Merge Albums will fix it.”
It can be a pain to patch things up. I would advise waiting to import new music until after an update fixes the issue.
The short-term fix:
