Who makes it and where did you get it?Hi,
Is that a special carpet?
What do you have behind your seating position? How far are you from the back wall?
I have placed absorption behind me and found it was beneficial in obtaining a more relaxed sound.
Yes it is a very thick acoustic carpet, room is less bright even though it was not a bright room in the first place.Hi,
It's a big French store called Saint-Maclou, they have huge selection of carpets for all kinds of use.Who makes it and where did you get it?
I suggest Jorma cables, I have Prime and that cable fits your needs perfectly, my system needs the oposite thus selling.Hi guys,
I'm looking to try new speaker cables and interconnects in my system because i find my Gryphon cabling too clear for my speakers and the treble tends to be fatigueing in the long run.
I need to try 100% copper cabling only and the ones that come to mind are Tellurium Q Statement and Audience Front Row.
I only need a set of speaker cables and one set of balanced interconnect.
Please let me know if you have suggestions so i can get a smoother sound thanks.
I ordered Cardas Clear Beyond SC ans IC, should get them within 10 days.I suggest Jorma cables, I have Prime and that cable fits your needs perfectly, my system needs the oposite thus selling.
Did you ever get to listen to the Tellurium Q?I ordered Cardas Clear Beyond SC ans IC, should get them within 10 days.
Yes i did, didn't like the Statement IC not at the level of the SC of the same brand.Did you ever get to listen to the Tellurium Q?
I totally agree with that.Yes i did, didn't like the Statement IC not at the level of the SC of the same brand.
I want to share my recent experience with different speaker cables in my system. My comments must be taken in the context of my system/room and my preferences. I'm not saying cable X is better than cable Y. I'm simply describing what I heard in my system. In the past two weeks I've been able to compare Nordost Odin 1, Audience Frontrow, and Shunyata Alpha v2 speakers cables to Clarus Crimson in my system.Shunyata V1 or V2?
Sorry i missed that, the TQ SC were smooth but lean and a little boring in my system.I totally agree with that.
What kind of differences were there between the TQ and Cardas speaker cable?
Which Cardas speaker cables are these?Sorry i missed that, the TQ SC were smooth but lean and a little boring in my system.
My feeling is that you don't get what you pay for.
The Cardas SC on the other hand for a little less money were much better performer in my system with great resolution, full body, and best bass i've heard to date from any SC cables.
Built quality of the Cardas is much better than TQ.
Hope that helps.
Hello Thieliste,Soon will also demo Cardas Clear Beyond SC, Clear Reflection SC and IC
Yes Clear Beyond.Which Cardas speaker cables are these?
Are these Cardas Clear Beyond SCs?
Hi Ron, Yes at the time i had the distributor over at my place with Clear Reflection and Clear Beyond SCs and ICs.Hello Thieliste,
Did you ever have occasion to compare Clear Beyond interconnect with Clear Reflection interconnect?
Thank you.
We compared both looms in my system and i definitely prefered the Clear Beyond, it's got more of everything and a much deeper fuller bass.
Reflection is not as transparent and open but warmer.
Since i wanted a long term cable loom i went with Clear Beyond.
high purity copper wire - such as PCOCC, provides a smooth sound compared to something like silver-plated copper or silver; especially with slightly longer runs. all the best!Hi guys,
