What turntables do you use? Pictures would be nice as well :-)
groovemaster
110
234
283
Actually, not much needs to be said about the Thorens TD 124.
The reasonableness of a relaunch can also be discussed. The new Thorens TD 124 DD shows a, in my opinion, very successful example of a modern revival. An AS community member has fulfilled his dream and placed this modern Thorens TD 124 DD with AS Phonolab next to the Garrard 401. His profession as a writer brings it with him to go on an exciting journey through time with vinyl as well.
groovemaster
groovemaster
110
234
283
Not everyone can say that they own a moated castle. One community member is in the fortunate situation of having his music room in a moated castle.
At the weekends, he can withdraw from everyday business and listen to his jazz records under the protection of the historic walls. Very important for an owner of a consulting agency to clear his head.
On the left a Scheu turntable in black/chrome with Sorane tonearm. A combination that fits perfectly.
On the right is the AS Phonolab with RECOMPIZER from Audiospecials.de. Also Made in Germany. On the right, with a silver front, an AIRTIGHT Masterpiece amplifier amplifies the vinyl messages to the speakers.
tom539
Active Member
Dec 28, 2021
50
166
40
50
Hello folks,
registerd for a while, it is time to start with my first post here in what´s best - with my two turntables:
Bauer DPS3iT with vdH Colibri XGP - my reference.
Micro Seiki DDX1500 with two arms - to play...
- FR64s cooper + SPU Classic GME II
- Sorane TA-1 with different cartridges: Benz Ruby Z with Yamamoto HS-4, AS Fidelis, Jico Seto Hori
atb, Tom
gleeds
787
1,284
235
Wave Kinetics NVS with Durand Tosca and Goldenberg Maestro cartridge.
As a second and somewhat less expensive offering, the Ars Macinae M1 will arrive in June.
I love Ricard's Teres "woody" and the Sansui tuner too!
tony22
591
258
153
63
I mentioned this in another thread, but well, here it is. :D
The production VPI Avenger Direct, serial #0001. The second pic shows the motor controls, but was taken before it was all put together.
gajgmusic
49
29
923
Hello folks,
atb, Tom
I love my Bauer table. I did have challenges with isolation but have solved it with Symposium. Great set ups.
slim9
3
6
308
Oracle Delphi Mark lll Graham 1.8t Koetsu Rosewood Signature w/Origin Live power supply.
Kcin
662
846
275
Canada
Added the FR66s w/Koetsu Jade Platinum IMG_1179.jpg
shakti
1,444
2,411
480
Cologne, Germany
one more classic arrived @home
Basis Audio Debut Gold Standard
still looking for a nice black / gold Tonearm. Must fit into the 214mm drilled base.
Rekmeyata
29
26
18
68
I thought I would post my just so this site would have some trailer trash components instead of all of those $10,000 plus turntables, my Rotel RP1000 cost $20 then later added a $75 Empire 400tc cart that an old stereo store had a NOS collecting dust so he gave me a deal, that really improved the sound and opened up the soundstage from the old ADC cart; then a bit later after that I upgraded the mat to a Hudson HiFi yellow acrylic mat which made a big sound improvement as well from the rubber mat, I had also had a cork mat but it didn't sound near as good as the acrylic mat and only a tad better than the rubber one; I then added isolation feet. The below one is not mine, but it's exactly like what mine looked like when I bought it; I remove the dust lid when I play my records so that the lid doesn't amplify vibration into the turntable. My next project for it this summer is to dampen vibration more by making a: DIY turntable isolation base with Ikea Aptitlig, that is on YouTube and he shows step by step how to make it.
Ok, now you guys can stop laughing and go back to showing your uber expensive turntables!
Salectric
381
501
998
