www.atma-sphere.com
I've been using them since last June. They have replaced my M60 Mk3 with Caddock, V-cap, PSU upgrades and selected tubes. I was planning to go back to the M60's for the winter but never bothered to put them back in the system. No need.OMG I so want to try this. I have a Purifi based amp and have had a GaN Fet amp in house as well. Love to hear what Atma-Sphere has wrought!
Yes.A solid state ampthat doubles down?
Is this heresy,blasphemy or both?
That interests me even more! I am spinning the Lejonklou Boazu integrated at the moment.Which only lends credence to the probable validity of his new product. Not that Ralph needs it.
Said to be also making an Integrated version soon which has my attention.
The most transparent one possible. I designed custom remote-controlled attenuators for my system a few years back. They are balanced, use relays and Texas Components resistors and are located right at the input of the mono-block amps.@aLLeARS what pre are you using with the Atma amps if I may ask?
The correct link is http://www.atma-sphere.com/en/resources-common-power-amplifier-myths.htmlJust for fun ypu might want to take a look at this atma'-sphere white paper.
Doubling down good or bad?
Would you likely be doing an integrated version, do you have any pics, thankyou.
Are you likely to do an integrated version? any pics of the monos, thanks.
