I have measured with a analogue oscilloscope as well, but the Fluke I normally use is just a digital multimeter with a minimal sensitivity of 0.5mV AC.Is your Fluke a scope based meter?
Any hum will be from the amplifier, not the heater/filament of the triode. If the filament is powered correctly by the amplifier then there should be next to zero hum anyway. Filament hum is dependant on the amplifier design, in particular the filament circuit and whether its AC or DC supplying the filament. If your 300B amplifier is prone to hum then it probably has AC feeding the filaments, in which case there should be a hum bucker circuit in the amplifier, where you can adjust or buck the hum out to acceptable levels. This is far from ideal because as the tube ages the hum can reappear and then it requires further adjustment. FWIW we had an 300B amplifier here a few months back with a pair of the latest production WE 300B's, but one of them was very noisy. It was not a hum, but a rustling noise that was present while the amplifier was on. The owner sent the 300Bs back and the noisy one was replaced by WE. With todays circuits it is possible to have zero hum (50Hz or 100Hz) on any DHT based amplifier.Hum from the heater.
Graham, mildly off topic I know, but what did you think of the new prod WE 300B? I run an AirTight ATM300B w/ WE 300Bs about 1996 production (when I bought it from Arturo at AXISS), RCA red-letter 12BH7s, orig GL Genalex B749s and a c. 1940s RCA 5U4G rectifier. Just curious, respect your ears...Any hum will be from the amplifier, not the heater/filament of the triode. If the filament is powered correctly by the amplifier then there should be next to zero hum anyway. Filament hum is dependant on the amplifier design, in particular the filament circuit and whether its AC or DC supplying the filament. If your 300B amplifier is prone to hum then it probably has AC feeding the filaments, in which case there should be a hum bucker circuit in the amplifier, where you can adjust or buck the hum out to acceptable levels. This is far from ideal because as the tube ages the hum can reappear and then it requires further adjustment. FWIW we had an 300B amplifier here a few months back with a pair of the latest production WE 300B's, but one of them was very noisy. It was not a hum, but a rustling noise that was present while the amplifier was on. The owner sent the 300Bs back and the noisy one was replaced by WE. With todays circuits it is possible to have zero hum (50Hz or 100Hz) on any DHT based amplifier.
Indeed, the hum is at such a low level that most speakers with less than say 106dB sensitivity will not hear it at all. And yes, turning the hum bucker can cause the hum to increase or decrease. But with the other 300Bs, some tubes are not so stable and one needs to adjust the hum bucker from time to time. With the WE300B, I have not noticed this. The 300B heaters are fed with AC. People have debated the merits of AC vs. DC heating for DHTs for a long time, but purists tend to stick to AC.Any hum will be from the amplifier, not the heater/filament of the triode. If the filament is powered correctly by the amplifier then there should be next to zero hum anyway. Filament hum is dependant on the amplifier design, in particular the filament circuit and whether its AC or DC supplying the filament. If your 300B amplifier is prone to hum then it probably has AC feeding the filaments, in which case there should be a hum bucker circuit in the amplifier, where you can adjust or buck the hum out to acceptable levels. This is far from ideal because as the tube ages the hum can reappear and then it requires further adjustment. FWIW we had an 300B amplifier here a few months back with a pair of the latest production WE 300B's, but one of them was very noisy. It was not a hum, but a rustling noise that was present while the amplifier was on. The owner sent the 300Bs back and the noisy one was replaced by WE. With todays circuits it is possible to have zero hum (50Hz or 100Hz) on any DHT based amplifier.
Indeed they have. Trouble is that triodes like the 300B are extremely sensitive of filament voltage and current. Even 2% to 3% (mostly below 5 volts in the case of a 300B) will have a significant degradation on the audio performance. Most of the 300B amps I have had through my workshop over the years have never made 5 volts. Most are around 4 volts and because they are AC heated they cannot be adjusted or corrected to make 5 volts. This is made worse due to the filaments of most 300B's not being the same. Example: the WE 300 draws 1.2 amps, others like the EML 300B (WE copy) draws 1.3 amps (actually its a little more). The EML 300B-XLS draws 1.5 amps (also its a little more and nearer to 1.6 to 1.7 amps) which means the filament voltage will be much lower due to the increased current draw (increasing the current draw means the voltage drops). In most cases very few audiophiles rarely hear the full capability of the 300B for this very reason.Indeed, the hum is at such a low level that most speakers with less than say 106dB sensitivity will not hear it at all. And yes, turning the hum bucker can cause the hum to increase or decrease. But with the other 300Bs, some tubes are not so stable and one needs to adjust the hum bucker from time to time. With the WE300B, I have not noticed this. The 300B heaters are fed with AC. People have debated the merits of AC vs. DC heating for DHTs for a long time, but purists tend to stick to AC.
Actually, Bé Yamamura was the first to bring SET amplifiers to the UK prior to Audio Innovations and Audionote Japan. These found their way to Radlett Audio and Abbot Audio in the mid 1980's. Bé is an extremely well thought of designer in Japan. Back in the day, if he wrote a technical article in a Japanese HiFi magazine, about 6 Japanese companies would produce their version of his design. The RS Labs tonearm is an example of this. Also, Snell didn't make horns. You are probably referring to the Snell Type A speaker which was a very large box design with a 3 way driver system (86dB) and for its day it was highly regarded.From a UK perspective - I think in the late 80's early 90's Peter Qvotrup intoduced the KSL/AUDIO Note Ongaku. BAck then £34,000 using snell horns, fronted by the Voyd reference using a Helius Cyalene. I know HiFi Choice and What HiFi in the UK went gaga over them. It popularised the notion that if things don't measure well it means nowt in terms of musicality. I've not heard this famous audio chain. Valve amps became significantly more commercially available such as Audio Innovations too. Remember until then the Krell KSA's were seen to be the holy grail of audio driving Aprogee Scintilla's - IMHO still an astonishing combo.
Revolution, or fad?
Just for information: I imported the original AirTight ATM300B into the UK about 20 years ago along with the other AirTight amplifiers so I know all their amps quite well.Graham, mildly off topic I know, but what did you think of the new prod WE 300B? I run an AirTight ATM300B w/ WE 300Bs about 1996 production (when I bought it from Arturo at AXISS), RCA red-letter 12BH7s, orig GL Genalex B749s and a c. 1940s RCA 5U4G rectifier. Just curious, respect your ears...
Way less a fad than any tweaksEvery time I’ve heard one they sound wonderful and musical - that said I’m not a fan. I’m not sure it’s fair to call them a fad given that their topology has withstood the test of time since about amps were first made in 1912 by Lee de Forest (less of a fad than cables and fuses - )
It makes me happy to know that you have a dance party rig... The best dance rig I have still has SET amp ...
It makes me completely happy as well… I worked in nightclubs in my earlier days and my family owned some as well and when we were younger various hotels and bars… and then there was the dance scene in the 80’s and 90’s… the body may have a bit less stamina but still the dance demons hold some sway.It makes me happy to know that you have a dance party rig
No fad, people are judging with their ears and many are finding more "truth" in the SET amplification.Revolution, or fad?
All you need is an 80’s mullet haircut from the front short and serious - from the side party at the weekendIt makes me completely happy as well… I worked in nightclubs in my earlier days and my family owned some as well and when we were younger various hotels and bars… and then there was the dance scene in the 80’s and 90’s… the body may have a bit less stamina but still the dance demons hold some sway.
Just before the lockdowns began a while back we got together for a reunion of a band with a mate I went to high school with who played in a pub band that played music by The Cure, The Smiths and The Clash… loved that, was joyful and wild to be able to go back to that time.All you need is an 80’s mullet haircut from the front short and serious - from the side party at the weekend
Indeed; TYVM caesar; just bought the set on CD.Thank you so much! I will check these out
