Thank you....yes, i happened to come across elusive disc and emailed them but did not hear back. So i have gone with Acoustic Sounds thanks to you.
I will say, i feel fortunate that finally, i feel like i enjoy listening to large-scale symphonic music on my system as much as smaller scale acoustic or hip hop/rap. Something to do with the amp being able to drive the signal thru the speakers with the level of dynamics, instrument separation that always felt constrained/smashed together...which bugged me before. I am playing Karajan's Beethoven symphonies now and really enjoying it. So now i am really looking forward to hearing this version of Vivaldi Four Seasons on my system.
Thanks, Lee. I decided to go with SACD version of Jazz of Pawnshop 1 and 2 (which were 1/3rd the price of K2)...but i elected to go with K2 of Time out and also of Kind of Blue since i prefer those albums more.
Same with U2, Sting/Police. But i have found on a couple that the remaster was at most 20% better...and probably mainly revealed on a very, very revealing system. In cases where i really, really cared about the album, i have bought the MoFi after owning the original CD and found the MoFi to be better..
Which set? I'm aware of four Karajan sets:
with the Philharmonia on EMI from the 50s
with the BPO on DG from 1963 (some people think this is the best set)
with the BPO on DG from the late mid-late 1970s
(Some people think that this performance of Sym. 9 is the best)
with the BPO on DG from the 1980s (Karajan at his most polished.)
I'm always interested in hearing what other people have to say about specific recordings.
Most recently, I have been taken by these recordings
Kremer / ECO on a DVD video (a brisk walking tempo for Winter/ii stayed in my mind for months. Later, I got the DVD and separated the audio. The tempo seemed too quick now.)
Shaham / Orpheus Chamber Orchestra on DG (An all around winner. Another brisk walking tempo.)
Julia Fischer / ? on YouTube videos (everything is convincing, very lovely Winter/ii)
Bill
I have the one from the early 60's on DG. ... I also own the full Harnoncourt set... Hadyn was a true master in breaking from Bach, imho, and Beethoven made the full leap. ...Hence why i prefer Karajan over Harnancourt...except in 9th where Harnoncourt's 9th somehow is so powerful, with a rich touch which seems to bring more majesty to the performance. ok, that's enuf of me being a critic...which i am not.
On Vivaldi, i have the Marriner (24/96 remaster onto CD), the Hogwood Ancient Academy and the Biondi. ... though i do like the tonality of the Ancient instruments...
New remaster of the Stones 'Some Girls' is an obvious improvement over the original CD -- greater clarity throughout the frequency spectrum.
I think it's unlistenable... I'd rather listen to my original LP
That's the problem with large-scale symphonic music - you need power, and lots of it. I have a new-found respect for lots of power after spending a weekend with the Colosseum amplifier you now own, and with working on a new design for my own high-powered monoblocks. I know that I'm always saying that the 1st watt is the most important one, but with large orchestral works, to get closer and closer to the "ease" of the live performance with more and more power.
Those dynamic swings come about when the amplifier works properly up to the limits of its power supplies; the really simple way of doing it these days is to put in a monster power supply, way above what is really needed, a sledgehammer to crack a nut, and then you have the "headroom" in the power supply so that it is always cruising at desired volume levels. Once you ask a conventional power supply to drop back from the cruising gear to a lower gear to get up a bit of a hill, then it starts falling apart as far as SQ goes ...Real Music even when not symphonic breathes with large dynamic swings .. For most speakers including those in the mid 90 db of sensitivity, that means at least a couple of hundreds of watts in most living rooms ... I am yet to becovinced of the contrary...
Hi
My sentiments exactly... I have tried to understand the flea-powered amplifer fascination .. Could not .. Real Music even when not symphonic breathes with large dynamic swings .. For most speakers including those in the mid 90 db of sensitivity, that means at least a couple of hundreds of watts in most living rooms ... I am yet to becovinced of the contrary...
Frank
My sentiments exactly... I have tried to understand the flea-powered amplifier fascination .. Could not .. Real Music even when not symphonic breathes with large dynamic swings .. For most speakers including those in the mid 90 db of sensitivity, that means at least a couple of hundreds of watts in most living rooms ... I am yet to be convinced of the contrary...
And the road that goes around this very expensive path is active. If the engineer knows the exact load of the specific driver that each amp in a multi amp system is driving, if there are no passive crossovers in the path between that amp and driver adding to that load and making it less predictable, such big, expensive iron is not necessarily required. The right iron for a very specific job. Or at least that has been my experience. Some of the best headroom I've experienced -- characterized by extreme openness and clarity and an easy, unstrained performance through transient peaks -- came from active monitors with plate amps built into the speakers themselves. Mind you, they're not necessarily weak. My own deliver 75 watts to each tweeter and 250 watts to each mid-bass driver. But there's no room for "big iron" in there.
