Thank you,I did the woodwork myself, in a friend's carpentry workshop.Thanks for the write-up and pictures about refurbishing your Thorens 124. Appears to be some intricacy with a complete dissasemble. Did you do the woodwork yourself? It looks nice.
Do you know which particular NTI meter you used?
I don't quite understand about the air suspension. Is that the footers under the slate base?
I use nti xl2 for mesurements
NTI Audio XL 2 M4261 Set
NTI Audio XL 2 M4261, Audio- und Akustik-Analyzer zur Lärmüberwachung und Überprüfung von Audio-Geräten, inkl. M4261 Messmikrofon Klasse 2, WAV-Aufnahme zur Dokumentation von Messwerten und Aufnahme von Kommentare auf Mini-SD Card (2GB inkl.),...
the air suspension only works correctly with a certain weight on the three feet. it blocks all vibrations above 3.5hz
