congrats to Magico for pushing the boundaries.
How is introducing a simple 2-way electronic crossover for $48,000.00 pushing the boundaries? Are you referring to pushing the previous profit margin boundaries? Enlighten us on how this crossover pushes any other boundaries? What features does it offer that are innovative?
www.pureaudioproject.com
Regretfully only single ended connections, and no phase adjustment.![]()
PAP-C1, Custom Active Analog Crossover for Open Baffle - PureAudioProject
I expect to get this product next Wednesday.
After I get it, I will give my opinion on it.'
It is made my "First Watt" team.
@HenryD thank you so much for your insights on adding the JL and Pass. I thought this might be the case but was hoping the benefits outweighed the penalties. I run my TAD’s full range and just have the subs coming in mid 30’s. I suppose I’ll just live with it as is. I posted on the TAD forum here if using port plugs would be a solution (making my speakers a sealed design) but got no responses.
I agree, $48,000 for a simple 2-way electronic crossover is absurd. I did not have a positive experience when I purchased Q5s from Alon, so perhaps I'm biased.How is introducing a simple 2-way electronic crossover for $48,000.00 pushing the boundaries? Are you referring to pushing the previous profit margin boundaries? Enlighten us on how this crossover pushes any other boundaries? What features does it offer that are innovative?
I believe it is expendable to a 4-way crossover.
Pass Labs XVR-1 is a dual chassis, fully discreet analog circuitry X-over. it is also extremely flexible, allowing for approx. 1,000,000 (yes, that right, ONE Million) settings with multiple X-over points for Low and High pass separately, and 4 different slopes (6 dB, 12 dB, 18 dB and 24 dB). Allows for both SE and balanced connections. Can be expanded from basic two-ways to up to 5-ways. MSRP is $5,200 For the base 2-way configuration.$52,000?
This PAP-C1 is essentially the First Watt crossover which Nelson Pass designed, set up for the Pure Audio speakers.I'd settle for balanced. Anyone know if they plan on offering one?
I agree with all your points, however ...Pass Labs XVR-1 is a dual chassis, fully discreet analog circuitry X-over. it is also extremely flexible, allowing for approx. 1,000,000 (yes, that right, ONE Million) settings with multiple X-over points for Low and High pass separately, and 4 different slopes (6 dB, 12 dB, 18 dB and 24 dB). Allows for both SE and balanced connections. MSRP is $5,200.
MAgico- One fixed X-over frequency and one slope. $48,000. Essentially it can only be used with subwoofers.
Beyond ridiculous
Not sure if it is fully discreet (lots of opamps inside). Although it cleared up the sound, running the main through it was not to my liking.Pass Labs XVR-1 is a dual chassis, fully discreet analog circuitry X-over. it is also extremely flexible, allowing for approx. 1,000,000 (yes, that right, ONE Million) settings with multiple X-over points for Low and High pass separately, and 4 different slopes (6 dB, 12 dB, 18 dB and 24 dB). Allows for both SE and balanced connections. Can be expanded from basic two-ways to up to 5-ways. MSRP is $5,200 For the base 2-way configuration.
Beyond ridiculous
fully discreet, not an opamp in sightNot sure if it is fully discreet (lots of opamps inside). Although it cleared up the sound, running the main through it was not to my liking.
