Yes. The combination is light years ahead of any other mat or clamp I have tried. Expensive but I don’t know of any other way to achieve this level of vinyl enhancement.Miniguy,
Are you using the matching Harmonix CombaK mat?
Very cool.
Much more inner peace in the music, finer gradations of tone colors.Very cool.
So, have you got something in mind already? What would you replace it with?I use the Audio Tekne CH-10 carbon mat. A huge improvement in sound quality. It’s 10mm thick so you need a longer spindle. You see I can just barely get an LP on. Not in the picture I do use a thin leather sheet on top also. I like it so much I’ve abandoned my TechDAS vacuum hold down and will eventually replace this table with something that has no vacuum and a longer spindle.
View attachment 85678View attachment 85679
i have 6mm. available 6mm,8mm ,10mm. also 20mm thick, but it weighs 2.3kg and can be dangerous for some platter bearing.Sweet. How thick is the mat?
My kind of vinylphile. Flipping lp a lot so no record weight on practical reason.
GorgeousThe Kuzma Stabi R wood (Sorane Arm, Phasemation cart) is now connected to the RCM Big Phono.
50kg turntable plus 35kg Phonostage in a heavy duty rack
View attachment 85722View attachment 85723
Thinking of CSPort TAT2So, have you got something in mind already? What would you replace it with?
My kind of vinylphile. Flipping lp a lot so no record weight on practical reason.![]()
Half of the times don't. I use record weight that came with my AS2000. When play 927 I don't use any. When I do, it is for flattening the record and a psychological thing. I do hear different sounds using different record weights though.Hi Tang
I have record weights including a nice Furutech, but prefer the sound naked on all my tables.
To add for me, life is too short to be screwing on and unscrewing clamps just to be able to spin vinyl. One reason why I never really gelled with the Monaco turntable I babysat for 3 months.
Do you use record weights / clamps?
