Ah, thanks. So that means amirm won't post a honkin haversine plot that's three times wider than my monitor??We prefer 800 x 600
Cheers, john
You need a new monitor. That was my desktop shrunk by one level alreadyAh, thanks. So that means amirm won't post a honkin haversine plot that's three times wider than my monitor??
Cheers, john
Cheers, john
I didn't think so...Ah, sorry, no it does not mean that...![]()
An excellent path to follow, Davey. Unfortunately, very unfortunately, every just straight physical contact is a weakness, so if you solder it would be an excellent move. The very first thing I start doing 25 years ago was to bypass every metal pushed onto metal contact with a soldered link, and that allowed me to make major progress.I do believe that it is possible that the design of the connectors inside the plug ( prong or iec) may have something to do with the performance. This would make some sense as the connection at the plug to the wire could induce losses. One interesting thought, which I think Frank may have touched upon in another thread, is to solder the wires directly to the component in question. Thereby, doing away with any potential loss due to the plug. I did not do this so I have no basis in this regard.
I had started a thread on power cables a year ago... interesting read, for sure. My opinion hasn't changed - assuming the right gauge for each application, they can affect impedance between the component and the wall (i.e. how fast they can deliver impulse current), and they can affect noise (both in the power line and as potentially radiated by the cord around it).
You hope, Gary, you hope. Sorry, it's not that easy: if you actually go through a proper exercise of simulating what happens in an ordinary power supply, you discover it's a bit of a disaster. That lovely DC voltage is very susceptible to being affected by what happens on the main's side; and, likewise, what the amplifier does to the mains voltage is very nasty indeed. That big Krell is giving your household circuitry a very unpleasant time ...For one, there is no impulse current requirement - unless an amplifier is directly connected to the IEC inlet. There is always a capacitor bank that will supply the sudden draws of current that music requires. Then, between the capacitor bank and the IEC inlet, there is usually a large transformer. These two will filter the impulse (or anything remotely music-related) from the input requirements.
Even better. I've used the voltage of the DC supply to drive another amplifier, a "perfect" voltage source becomes just another input to an audio system. And very eye opening it is too: as I've said before, could be a great backing track to some hip hop, or techno music ...And you've hooked up an oscilloscope to the capacitor bank and seen the voltage on the bank vary with the music waveform? Pray tell how does a big Krell with a linear power supply give the household circuitry an unpleasant time. I do acknowledge that a switching power supply will, but a linear power supply?
Try as much as I may I can't begin to see how a competent (of sufficient gauge to carry all the amperage the DUT will ever need) power cord could contribute to voltage sag ....Gary,
one aspect I never really seen mentioned is that of voltage sag when the amp is working harder.
Always wondered if this trait can be influenced by the realworld power cables (not theoritical spec ones that do not exist before anyone gives an example).
Cheers
Orb
Gary,
Cheers
Orb
Power Cord discussions are to me the epitome of our audiophile obsessions... We conclude they make a difference based on difficult to substantiate or replicate observations .... Then we go fishing for morsels of 'science' which would correlate to the (suspects) observations.. It should noted also that Science is rejected in the very same discussions and often by those who invoked it.
Gary,
Cheers
Orb
(...) l am not accusing the whole audiophile community of rejecting science but if I were to just gleam around here in the WBF, the tendency to reject science is patent. Many (not all) do proclaim that some phenomenon can heard but cannot ever be measured so what to make of that?
There was no intent to bash but there was an intent to wonder about the validity of our conclusions about PCs.
