www.destinationaudiousa.com
I will not pretend I fully understand the measurements, but what JA says in his final comments ("Summing up the Volti Rival's measured performance is difficult: Its perceived balance will depend to a greater degree than usual on the listener's choice of music and the size and acoustics of the room.") just stops me dead in my tracks: IMHO, quality speakers should definitely be "genre-agnostic"...Eyeballing John Atkinson's measurements, the impedance curve of the Volti Rival does not look particularly SET-friendly to me.
Such high praise coming from you means a lot!Those big Radians are what I would be using if I were doing coaxials.
I would definitely like to get away without needing subs. Could you please clarify what you mean by "ceramic version"? Is it the driver Magnetics / Diaphragm called "Prime : Ferrite / Aluminum" on the manufacturer's website, please?The ceramic version will have a bit more low end and might get away with not needing subs; the more efficient neo version would imo very likely need subs.
I wish I could afford this beauty and call it a day...I have been consistently VERY favorably impressed with the Volti Vittora
In the same league as Vittora! Wow! Do you remember, by any chance, what model from Spatial Audio were you auditioning, please? Was it M3 Sapphire or, perhaps, X3?I have heard a Spatial Audio speaker which used the 15" neodymium Radian coaxial (with the aluminum diaphragm), augmented by a separate dedicated woofer, and imo it was in the same league as the Vittora.
They are beautiful indeed...nice, and easy to drive. .
I also noticed MGRA Floorstander goes 7 Hz deeper than GRA Super Monitor. Is it just due to the bigger internal volume of the speaker cabinet?![]()
Your Bohemian is truly a work of art! Just to make this beautiful horn takes a lot of knowledge, research, and experimentation. My most sincere congratulations on such high achievement!![]()
maybe the guy in the video is only 1.5m "tall"Nah...not big enough.
This is very interesting.will it be better than the klipschorn.?A recent video of the new Klipsch Jubilee that's due out this week...that's apropos to this topic, I believe:
Chris
Apparently Christoph they’ve utilised DSP to help extend him up a bit more up top… so now he is closer to 1.8m highmaybe the guy in the video is only 1.5m "tall"![]()
Nope. That's his toupee.Apparently Christoph they’ve utilised DSP to help extend him up a bit more up top… so now he is closer to 1.8m high
Chris
Thanks Chris for this video and welcome to wbf.They use the relatively new "full range" Celestion Axi-2050 (2") compression drivers with a new phase plug extension that Roy has just revealed that apparently helps spread out the polars above 7 kHz. More on that driver on a K-402 here: Celestion Axi2050 2" compression driver on K-402 horn.
Chris
In this case, you owe that to yourselfI am thinking of buying a pair of these already.I own 2 pairs of la Scala and a pair of klipschorn.
I have being using klipsch speakers since the age of 15 when I bought my first pair of klipschorns.In this case, you owe that to yourself
..and to Klipsch as well![]()
