The Aries Cerat Symphonia is also fully horn loaded and good to around 30Hz. They also have a fully horn loaded sub to go with it.Hi,
Indeed there are not many fully horn loaded systems available (20hz to 20khz). The community at large have adopted the nomenclature “horns” even when they are referring to a hybrid type system (horn on top and non horn bass solutions whether it be reflex, open baffle, etc).
It is often not the case that the user wouldn’t wish for bass horn loading but the practicalities of achieving this are extremely challenging due to physics. Very few audiophiles (and their wives) are willing to accommodate the colossal size needed.
In terms of your last point - in fact there are indeed some fully horn loaded systems on wbf. Leif’s is such an example, both the massive Cessaro systems of Jeroen and Tang are, Sven’s horn solutions systems, and probably a few others.
Fwiw - some very big proponents of horn loading including Romy the Cat (see his forum) don’t feel compelled to cover their lowest octaves with horn loading - Romy uses a bass line array for instance.
Hope this helps.
My Odeons are also fully horn loaded where the mouth of the horn opens the floor and this extends the horn . Bass to 40hz but not much below that.
Finally TQWT offers a type of horn/reflex hybrid that goes a bit deeper than a normal exponential horn but has speed and punch unlike sealed or vented boxes.
