Border patrol has a R2R dac with a tube. Might be what Ron is looking for $2k.
Check out the new SCHIIT Yggdrasil “Less Is More” DAC.... Uses Four TI Dac 8812 chip’s .
The current “buzz” on the Internet is that this is their best DAC so far. They actually have 3 different versions of the latest Yggdrasiil DAC, with three distinctive tonal flavors. The “Less is More” model has the most “Analog”, sound characteristics of the three, ( the other two are described as “ Neutral” ( the “MORE IS LESS” version, and finally the “OG” version, being described as the most detailed, etc. Anyway something to consider, although it’s less money than your target search bracket ( 2199.00 to 2599.00 for the OG version).
Cheers....
Not exactly sure what they are doing, other than the use of different DAC chips in the three versions of the Yggdrasil, and then tuning them for different sonic presentations .....There are various reviews of these new Yggy models on the Internet that probably can answer your question better than what I just indicated.....What is there a circuit design methodology for implementing these three different total flavors?
Schiit has, for a few years, been tweaking the output circuit in both the Yggy and Gumby to achieve a particular flavor of sound... A supposedly analog sound, thus the "Analog 2" upgrade offered originally which merely tuned the output stage. Now they've decided to offer up multiple Yggys, each with a different DAC chip in order to obtain improved measurements. They got reamed in Stereophile a few years ago for poor measurements that revealed apparent problems with the digital circuitry at the time. And they have now apparently responded with a pick your poison solution. One DAC, three entirely different converter chip options, one of which they claim now measures quite well. Odd, in my opinion. Certainly unheard of.What is there a circuit design methodology for implementing these three different total flavors?
I had for a few years Lampi B7 with R2R design. I loved it.When I compared some of the Lampi dacs with Lukasz he told me I have a preference for R2R. My GG is R2R and I could hear a distinct difference with chip at that time. It is in dynamic range, effortlessness, and flow. It is difficult to compare it to latter chip dacs as a lot apart from R2R and chip would have changed in between.
You should look for an Ayon Skylla 2, CD5Ss or S5 server with proper R2R BB1704 chips...and a very good tube output stage...would go great with your Crossfire...I had for a few years Lampi B7 with R2R design. I loved it.
2 hours audition of Pacific was enough to understand that is is a leap forward though.
Then my Pac was further upgraded and W20 new soft made possible native DSD playback instead of DoP. All together a new level of music reproduction.
But sometimes I miss my beloved B7…
I should have kept it in my 2 nd system, but one can’t have everything.
Stretch for another 0, the improvements are huge.Thank you, Roger, but I'm looking in the US$3,000 to US$5,000 range for a DAC.
A concern I recall in Stereophile measurements was the high error rate around the zero crossing. We weren't arguing so much over its existence at the time, but over it's audible effect.
I had a wonderful afternoon at the home of Phil (213cobra) on Tuesday! Phil's Bricasti DAC (one of the several he owns) can switch between delta sigma and R2R at the touch of a button. (...)
The BB 1792 is a pretty good Soundcastles by delta sigma DAC chip. I had the Audio Aero Prima DAC, which was just a capitole 24/192 without the drive. Nice sounding but too smooth overall and a bit soft on dynamics. I always thought the last Audio Aero DACs were very Good...often rooms at shows with them performed well.@morricab
My AA La Fontaine has BB 1792 as far as I remember, very good PCM DAC with tube ( micro triodes) output stage.
