It does play something according to the demo video, if it doesn't I'm going to ask for a refund!
This is big news if Taiko are going to start making little silver discs.
It's a priority for me as well
Did you listen to streamed files as well?XDMS raises the bar on Naturalness
I had my first listening session of XDMS playing files from storage this morning in Oldenzaal
Wilson and Emile have pulled another rabbit out of the hat. What struck me was the naturalness of the sonic presentation took another very noticeable jump. PRAT is up significantly as well. My 16/44 test tracks sounded like never before, simply amazing
To achieve this level of SQ needed a lot of rework of the program plumbing, but wow was it worthwhile.
Their efforts are Herculean and relentless, my hat off to the both of them
yes this is right place. I am sorry, I was not very accurate.Looked for this and I couldn't find any network icon in server settings, just the word network. Under that the only buffering is radio station buffer which was set at 3. I tapped the three dots in the upper right corner and went to server settings. Am I looking in the right place?
All of our testing has been with stored files so far.Did you listen to streamed files as well?
I do not.Just my 2cents: Does anyone really care about track bar manipulation?
We are still working on the streaming client, but it has taken second priority to getting the stored files sounding at a new level
It looks like I need to go back to daily check in hereAll of our testing has been with stored files so far.
We can’t use the TAS Qobuz and Tidal streaming clients for XDMS as they are Logitech Media Server plugins. The XDMS Streaming client will not need LMS and benefit SQ wise from being LMS free.It looks like I need to go back to daily check in here
I love the SQ reports on testing with stored files and I am fully copacetic with streaming as a second priority.
In fact, a release with the improved SQ for stored files and only(!) the current SQ for streaming would be fabulous as a solid first release point (if the effort to advance streaming SQ takes more time)
Its been a year since I’ve used Roon because TAS is where the future is but IIRC isn’t that a feature of Roon.Whether streaming or resident library, there should be a click-on or pull-down list associated with each displayed track, one button of which is "Add to playlist" that takes the user to a screen that allows adding the track to any of the existing playlists or allows the user to create and name a new playlist.
Normally there are more than one ethernet cables/segment within our home CAS network.I tried an experiment tonight. During the recent discussion about copper ethernet input vs. optical to the Extreme I disconnected the optical lead I had been using for over a year and connected a decent but no pretensions to being “audiophile” copper UTP ethernet cable. I had only used this copper ethernet cable once before to feed the Extreme the first two days after I received it, but quickly abandoned copper in favor of fiber optic.
Both runs, copper and fiber, originate directly from ethernet ports on my ISP provided DSL modem/router. Copper of course goes completely uninterrupted. Fiber is via a Sablon copper jumper from modem/router to the copper input on a Sonore OpticalModule. The OpticalModule is powered by a 7VDC Sonore Signature LPS further double-regulated down to 5VDC through a DXP regulator box.
Out of the OpticalModule via a Finisar SFP, single-mode fiber goes directly to a matching Finisar SFP in the Extreme.
As Emile mentioned, the copper ethernet cable isn’t at all bad and is more relaxed or forgiving in comparison to fiber. It certainly sounded better than I remembered it sounding the first, short go-round back when my Extreme was new.
With copper ethernet connected I played a bunch of albums I have that are a bit hot and a few that are downright harsh. All were more palatable and easier to listen to. So I left the copper UTP connected.
While iniitally I found the copper kind of growing on me, a week or so ago I started realizing that something just didn’t seem quite right with my system compared with how it had been sounding some weeks ago. Something or somethings were missing. Well-recorded tracks that used to fairly explode from the speakers were sounding, well, a little polite. And tracks that were expansive and immersive, filling the entire room with music were smaller and flatter than before.
I hadn’t moved any Tube Traps or other room treatments around or changed the location of anything, listening chair included. I finally figured out that the only thing I was aware of that had changed in the last several weeks was swapping optical cable for copper.
That was the culprit. As soon as I plugged the fiber at the Extreme and pointed TAS player at the new IP address of the fiber NIC the first track I queued up made it clear I wasn’t imagining things. While the copper input certainly tamed more egregious harshness quite nicely, in my system at least it ultimately proved to be a little too much of a good thing. However, I can hear how another system with a different balance might benefit from the touch of warmth and little bit of forgiveness of copper ethernet relative to fiber optic. It is something worth hearing and judging for yourselves if you haven’t already compared fiber to copper.
Steve Z
Hi Steve,I tried an experiment tonight. During the recent discussion about copper ethernet input vs. optical to the Extreme I disconnected the optical lead I had been using for over a year and connected a decent but no pretensions to being “audiophile” copper UTP ethernet cable. I had only used this copper ethernet cable once before to feed the Extreme the first two days after I received it, but quickly abandoned copper in favor of fiber optic.
Steve Z
Thanks for your kind reply. Actually, I am completely open to the idea that various copper ethernet cables can sound different from one another. I wasn't clear but the only thing I was trying to compare was a good quality but not audiophile UTP (unshielded twisted pair) copper ethernet cable such as what Emile mentioned (if I understood him correctly) against the fiber optic connection to the Extreme I've been using for some time.Hi Steve,
One small word of caution. You‘ve integrated all ethernet cables under the term ‘copper’, but I think you’ll find that what you’re hearing is related more to a specific cable rather than to copper in general.
I have standardised my network on Synergistic Research Atmosphere X Ref cables. A few months ago I was loaned an Innuos PhoenixNET to try and was short an extra SR cable so used an AQVox Edge cable that I’d since replaced with an SR. And the effect was as if I’d instantly stepped back ca. 15 months in my system development. I have upgraded a lot more since, but that single cable still added its own character to the mix. The reason I like SR is because I’ve found their cables to be exceptionally neutral and transparent to the actual recording and by adding the AQVox I introduced a sonic character that I instantly recognised from several months previously. I don‘t know about optical cables (I’m waiting for FTTP to arrive before I make a trial installation) but in the World of copper ethernet, when a system gets to the level of resolution you enjoy, a single cable can markedly change what you hear and those copper ‘limitations’ you’ve identified will almost certainly disappear with an ethernet cable that is more appropriate for your system.
The other area to consider is of course isolation. When I was first installing my system, the worst sounding configuration was a cheap ethernet Cat 5 cable between the ISP modem/router and my server. The second worst was a Synergistic Research Active Cat 6 ethernet cable. By far the best sound was obtained when a wireless link was introduced, first via a mesh network, then finally using a simple wi-fi to ethernet bridge arrangement.
have you tried any other form of network isolation?Hi Steve,
I agreed right up to WiFi lol. but if it’s goal is only isolation and use dhcp only it’s fine I feel. I use an online iso from emo tech at router network switch to my audio only router. This not only isolates but also keeps non audio traffic away , this is easily shown in a then be.Thanks for your kind reply. Actually, I am completely open to the idea that various copper ethernet cables can sound different from one another. I wasn't clear but the only thing I was trying to compare was a good quality but not audiophile UTP (unshielded twisted pair) copper ethernet cable such as what Emile mentioned (if I understood him correctly) against the fiber optic connection to the Extreme I've been using for some time.
I have experience with power cords, power distribution devices, interconnects, speaker cables, USB cables, clock cables and yes, copper ethernet cables all having their impacts on sound quality. However, given that distance from my DSL modem to the back of my Extreme is currently 20 meters, at audiophile prices a premium ethernet cable let alone several to compare to each other is just not in the cards. I may however try your suggestion of wireless, though space and outlets behind my equipment rack are definitely at a premium.
Steve Z
Hey K3RMIT, thanks for the reply. To be clear, I’m not a Taiko Extreme user, although I do track the technology with great interest and have learned a great deal from this thread and its contributors. My background is is in highly complex analytical systems and I tend to apply a lot of what I learned there to building hi-fi systems. My current system was started from the ground up for digital local and remote streaming for a single listener….. My previous system had focussed on making CD replay as natural and musical as possible and was therefore all tube based, but eventually I got tired of listening to music in a sauna. Its also based in a small room, which at first I thought may be a waste of time but which eventually, surprisingly and happily proved to be the best room I’ve had the pleasure to listen to music in, possibly due to the near field listening position, which I love. When I look at a system I tend to try and standardise as much as possible around components that provide that deeply satisfying reproduction that communicates the essence and spirit of the music without any conscious effort required by the listener and without any discernible sonic signature, so the establishment of my system has taken over 3 years, trialing many different products and networking topologies along the way, with the exclusion of optical, which I will trial once I get an FTTP service.have you tried any other form of network isolation?
how did this effect streaming music like tidal ? I would think the taiko would have an internal method of dealing with isolation over all . I do agree isolation is almost always a plus.
