hummmm?On a different topic, your post observes: "Multiple active platforms, such as those by Herzan and Accurion mentioned above, probably would be the best solution." (though you note neither your room nor your budget accomodate such solutions.) I am not a technology person but I have a somewhat technical question for you: if a component is capable of having multiple internal simultaneous resonances sometimes at different frequencies, and the component is subject to vibrations from external sources at the same time, how does an active platform deal with those? If my question makes no sense, I can handle that.Thanks in advance for your insight.
your question makes perfect sense.....to me.
i have 5 active isolation devices in my signal path; the Taiko Tana 'system'/Herzan. 2 for my amps, one for my preamp, one for my phono stage, and one for one of my turntables (where it can work due to zero self noise). really crazy and not cheap. off the deep end stuff.
the answer to your question is that an active device does not care where the resonance comes from, including the gear it's isolating. if it's piezo electric sensors read it, it will attenuate it. you can clap your hands loudly next to the device and see noise on the screen that is being attenuated. jump on the floor, tap on the gear same thing.
but you are right to mention different frequencies, which is why Taiko studied the Herzan TS active devices and developed the whole 'Tana' system, which includes a 10mm top layer of panzerholtz, a thin natural rubber membrane, and then Daiza on top. the Daiza product idea came from research developing the Tana platform. this Tana 'system' does cover the whole frequency spectrum. the active Herzan TS shelf does have some passive attenuation designed into it, but as the frequencies rise it's less effective by itself. so a system is needed to do the whole job.
DAIZA ISOLATION PLATFORM – Taiko Audio
i mentioned 'self-noise'. active won't work with gear that has sufficient self noise to cause a feedback loop; which will degrade performance and eventually burn out the motors. most electronics are fine, but most turntables are not fine. of my 4 tt's, only the NVS can be used......as i see zero self noise on the readout of the Herzan when playing records. no 'self-noise' to attenuate. note that the WBF member who just purchased the Techdas Zero is using a Herzan active stand for it, and tells us it improves the Zero performance. so the Zero must have no self noise into it's bottom case. and if it improves the performance even with all the isolation built into the Zero that tells us something too.
the other really big thing about active devices is that they come standard with SMPS (switch mode power supplies) which cause noise in the a hifi signal path, sometimes lots of noise. when auditioning an active device in your system you need to realize what might be causing the positive or negative results. you might be getting outstanding positive resonance attenuation, but the SMPS could be poluteing your signal path degrading the net benefit. or you could be getting self noise too. so it's not a simple thing to do an audition. it took me years to understand these things.
the Tana 'system' includes a pretty exotic stand alone panzerholtz cased LPS (liner power supply) which has no noise and improves the performance of the Herzan TS unit. lower noise, better performance.
oh and btw, with the whole signal path covered by active devices you do have some magic going on as the whole feedback loop of resonance is essentially broken, the whole becomes greater than the parts, and so reproduction musical truth is presented that is not otherwise accessed. it kicks ass.
active is not a universal solution blindly applied. it requires a solid floor and solid rack to work properly, so it is 'site' sensitive. and likely not all gear is designed to have resonance eliminated equally. in my system my dart preamp gets the least 'lift' from it as it's built like a tank and is already on the bottom shelf of a solid rack. when it works it's amazing.
