Be advised.....A combination of variable settings are available to the intrepid Symphonia owner
Midrange reproduction
The midrange horn is made from solid wood, it’s unique flare is designed to eliminate all possible diffractions, which all other horns suffer from, and are part of their sound character.
We completely eliminate diffraction coloration, which smears transients, with our 360 degree bullet-shaped solid-wood horns.
The driver used is large format (4inch diaphragm) titanium driver, with a massive magnetic system(11kg magnet weight).
The midrange acoustic level can be altered via a multitap transformer, for tuning the speaker according to each room’s acoustics.
Filter design.
The external crossover, consists of three constant group delay filters. A constant group delay filter, is our own proprietary design, which alters the attenuation slopes of the driver filters, to shape the phase(and doing so the GD)in such a way ,as to provide maximum GD linearity.
Using this specific filter technology to the physically time aligned horns, the Symphonia speaker present time domain performance which is near perfect, and a frequency response with a maximum deviation of +-0.5db (250Hz-20KHz).
Sensitivity : 101db
Frequency response(-3db) : 32Hz~100Khz
