By the way Tima. Thanks for putting this together and sharing.
About 1.25 cups of 95% isopropyl alcohol. All that was local. And about 6 drops of Triton x114 surfactant. I have about 1.5 gallons of water in the system.You are most welcome. Both USC tank and solution are key components. What solution are you using?
I ran 4 batches and my basement is starting to smell like a burning motor. I don't think my tank will be long lived. I run the batch for 30 minutes.
I am vacuuming my records when done. I taped the felt on my vacuum with blue tape. It seems to dry better.
My heat got up to about 31*. I am going to need a radiator.
I am using 1 kuzma puck between records and loading 5. Not sure if that is to tight for my weak machine.
I still see finger prints and have some surface noise.
I will order the lab alcohol and surfactant you call out. As well as a meter. I have a 1 micron filter. I guess I need to get the .35. Boy, I remember some time back when you started with 5 micron.
I kinda scratched my head looking at their picture of calipers on a hose barb. There is a well codified language for describing such parts. Always a good idea to keep watch on newly made connections.
XP-HF-720-20L-80KHz
High Frequency Ultrasonic Cleaner XP-HF-720-20L-80KHz /Out Of Stock
High Frequency Ultrasonic Cleaner XP-HF-720-20L-80KHz /Out Of Stock - 5.3 Gal. High Frequency Ultrasonic Cleaner XP-HF-500-20L-80KHz by SHARPERTEK® High Frequency Ultrasonic Cleaning Machines Used for Specific Applications. Features: Free Parts' Basket Industrial grade model Side Handles for...www.sharpertek.com
This looks like a good unit. But its going to be $1900. And its only 80 Khz. No duel function. The 40 Khz units are significantly less money. On amazon for say $300 or less. I assume my Kendal is a 40Khz. I will use that to rinse. If I feel the need. I really want to spin clean and call it a day. I don't want the process to take too long.
Folsom, why are you saying nothing is very hidden. The part of a record we want to clean is deep in the groove. I thought that was a very small area. I thought the idea behind smaller bubbles was the ability of the bubble to get deep into the smallest parts of the groove and pull out debris. If this were not the issue, I would continue to use my 1.5" square chunks of home depot micro paint brush and simply scrub the records. FWIW, that seemed to be a very effective method of cleaning. At this point in time, re-cleaning a record I did with a brush provided no sonic benefits I have heard. They are about the same.
The best results I have achieved so far on on the new record I put to the test. The solution I used seemed to have brought out more detail in playback. I only tried my solution on one record I like. So far I have been experimenting on classical records I got used that have nebulous value.
Tima, what is your take on Neil's Ilfotol only. Is he saying, in order to get the higher concentration of cleaner off the record after the wash, you have to apply a different chemical to remove the Ilfotol????? I need to reread all that. One pass was not enough. This stuff is all so intense. I feel I really need to start a word document and start pasting part numbers, specifications on formulations and process to keep it all strait. Its kind of like there needs to be a master page that is locked by you, and edited by you to only contain the most current and best information. The whole is an enlightening read, but its pretty overwhelming. And a process in flux. Changing as it is refined.
The real trick is you have to get it flowing before mounting it upside down. For whatever reason despite the natural advantage the pumps cannot deal with air bubbles when upside down.
The hz is very debatable.
From a technical perspective the 80hz works faster, not necessarily smaller. The thing about smaller areas is they're harder to get to, so more smaller bubbles will hit them more often. The thing with records is they're a big wide surface so nothing is very hidden - they're about as easy to hit as possible. The water rushes away from the implosion of the bubble, so that rush can hit areas of larger and smaller sized so long as the direction is there - they're just more spaced out at lower frequencies.
You're kind of winging it here. This is not correct.
Empty words.
Are you seriously going to trash Tim on his thread about a subject he has been researching and writing about for years?
You wrote stuff with absolutely no scientific evidence or proof. If you have it please share it.
I'm not trashing anything on Tim, he's saying that I'm incorrect on something and not posting any contrary information.
