Dolby B and its ilk generally boost the highs during recording to get them further above the HF noise ("hiss") floor. So, to play back a Dolby B (etc.) recording on a non-Dolby deck all you usually need to do is turn down the treble a bit.
Rich
why are you trying to complicate things
If I don't use it I will have to accept the sound of some of the Dolby B recordings without the Noise Reduction.
Rich
Rich
Well the Advent 100 Dolby B Noise Reduction unit arrived today. I am not sure if it is working properly and I can't get the meter test to work all the time. But, from what the sender indicated the unit works. The problem is that the machine has older RCA connectors which are too close together for my much newer high end RCA ICs with the screw type locking ends.So, I probably will not use the unit even if it works at this point. Of course the unit could be modded to have greater distance between the left and right channels for the RCA connectors. I will have to think this through more. If I don't use it I will have to accept the sound of some of the Dolby B recordings without the Noise Reduction.
Rich
Rich-Those tapes won't sound right if they are encoded with Dolby B and you play them back straight without it. Since the Advent isn't high on collector's lists, I would modify the unit and space the jacks apart. You may want to try it first with a cheap pair of ICs and make sure it works first.
here, Rich. I need to research and source a Dolby A and/or Dolby SR unit. My nascent understanding is that these units are "companders" and influence more than "tone".
Good luck with everything![]()
Rich,
You have your core cables in place. Running std grade IC's with your dolby unit won't degrade the sound. If you have a set of monster,mogami or other cables with std ends try that,it will sound fine. If there is any degradation it will be possibly from the dolby unit itself(maybe).
Hi Guys,
Thanks for the suggestions. I have hooked up the Advent 100 Dolby B Noise Reduction unit with it sitting on top of some Herbies Tenderfeet between it and my upgraded NuForce Oppo 83SE to test it and to protect the units. I found a couple of pair of throwaway cheap RCAs with smaller connectors. I don't have a calibrations tape, and as a result I am having to quickly adjust the unit by ear. But, it seems that the Advent is in fact operating properly. I am listening to the 4 track Blue Jays 7 1/2 IPS R2R tape by Justin Hayward and John Lodge. The meters are functioning properly. I had a glitch a few times for a few minutes when things didn't sound right. I was getting a high pitched whine coming out the speakers. I am not sure of the problem. But, I rewound the tape and things improved. I am not quite sure what happened, but I adjusted the output of the Advent after running the tape back. I am not sure if it is the tape, it is wound too tight or the Advent.
I am going to try side 2 now. I am not noticing the relatively painful highs that I heard on the tape initially though.
I will have to decide what to do regarding ICs (I am not sure what I have at this point for old cables and where they are). I know that I have some older Monsters and others but since we moved I will have to look around. Of course, I may have the RCA inputs and outputs changed as Mark has suggested.
Rich
Okay guys. I am open to suggestions. I dug up an old pair of Audioquest Ruby RCA ICs and 2 pair of Monster IC cables. Someplace there are some 1/2m Audioquest Laps X3 (as I recall) RCA ICs, but I think that they probably have the same connectors as the Audioquest Rubys. In any case, the Rubys don't fit the Advent, they are too big as is 1 pair of the Monster RCA ICs. The other pair of Monster RCA ICs are pushing the connections.
Should I have a tech replace the RCA inputs and outputs f the Advent 100 to take the better IC cables such as those that I already have or use really inexpensive RCA IC cables and/or the Monster cables? I am concerned that the I will lose performance using the inexpensive RCA IC cables.
Rich
I do not know the output impedance of the Dolby unit. I would not use the cheapest cables, though it might not matter; my default with unknown gear is to use low-capacitance cable and be done with it. Microphone cable is usually a good choice.
