PRE for the CANARY AUDIO GRAND REFERENCE
jasbirnandra
273
27
933
I have upgraded from the canary M600 to their grand reference amps but have not changed the pre of Canary C1800 I feel there is room for improvement
can anyone suggest a good pre which can be more 3 D and airy than the C1800
AUDIO RESEARCH 6 SE. Although I haven’t compared it with the C1800 that you have, I am very familiar with Canary’s M800 MK II, in the same system (mine), and the ARC is substantially better in all parameters. Might be worth looking into.
Cheers......
Cheers......
I can also confirm that the ARC preamps work quite nicely with the Canary gear. I've heard the Ref3 and Ref6 with various Canary amps.
Aries Cerat Incito, it works well with everything I have tried it with...it makes everything better!
