PleaseThere were subjective quotes about that shootout where they preferred JMLC
david
I didn’t, I posted to Duke's reflection diffraction comment and since he is a speaker designer, I thought he might find it useful
Maybe a speaker designer might find something useful in this but what did you get from this? The methedology is limiting and some of the horn/speaker pairings are wrong or strange, just look at the S2 and the Stereolab horn pairing. I wouldn't call this a shootout or conclusive only a record of what he found in his limited tests.
Look at those ears , Which one is Ked ...?
You should try first watt type or Berning quadrature or just biamping with low watt SETs and a higher watt SS or class D to the bass
Hi LeJeune,And I did indeed, though it took me a while to get past my antivirus software which thought the site was dangerous. Thank you!!
I still haven't digested all of the information in L'Cleach's measurements.
One thing that stands out to me is that the two "winners" are both round horns with nice big round-overs at the mouth. I forgot to mention in my earlier post that a sharp-edged lip can also be a source of diffraction and/or undesirable reflections. I THINK the "flower petal" lippage of the also-high-scoring Acoustihorn Conical (presumably a Bill Woods design) is intended to smear the reflection/diffraction at the mouth such that its effect is less concentrated, while allowing closer driver spacing than a big roundover would.
The winning general format isn't necessarily "news" to me, but it IS encouraging, as I'm currently working on round horns with big round-overs at the mouth.
Congrats on the forthcoming arrival of the new member of your family! Avantgarde Mezzo only needs a handful of watts, but my experience with Duo XDs is that too much power is no problem. Ideally you want a low gain amp, but I've used amps of up to 250 watts without undue concern and my current one is rated at 200 into 8 ohms.Avantgarde duo mezzo xd‘s arrives next week replacing Focal maestro utopia’s currently driven by Levinson 33h’s. Does anyone have experience of Avantgarde with Levinson or similar high powered amps. Thanks
Great Peter, just the type of response I was hoping for, thanks. Would you mind sharing which class D amp you’re using please, I’m happy to try any technology.Congrats on the forthcoming arrival of the new member of your family! Avantgarde Mezzo only needs a handful of watts, but my experience with Duo XDs is that too much power is no problem. Ideally you want a low gain amp, but I've used amps of up to 250 watts without undue concern and my current one is rated at 200 into 8 ohms.
If you can train your preamp to limit its output thus reducing the chance of over-blasting the speakers, so much the better. I suspect you could find an amp that offers a greater excitement factor to your music than the ML, but it's a trial and error game to find what you like best. I tried a dozen amps and eventually chose a Class D one. Shock, horror, but it sounds very good powering the Duos and is (I can only say this on this forum!) ridiculously cheap.
Let us know your take on the Mezzos when they arrive. You'll need a lot of setting up time to get them performing at their best, but well worth it and you'll probably be infuriated that the XD software needs external equipment (calibrated mic and measurement software) to be of real use, unless you are able to judge entirely by ear what needs to be adjusted. Your dealer should have a kit to help with this job but wait several weeks until you have the speakers positioned ideally (location, toe-in, tilt, etc) and they have a good number of hours on the clock. Good luck. Peter
Thanks again Peter, that‘s opened the options list. The Benchmark AHB2 is interesting as is the new JBL class G.Hi Chris. My equipment is in my Signature - it's actually up to date!
I made a conscious decision to move away from SETs that I'd been using for 15 years or so with Avantgarde speakers (Unos, Duos and now Duo XDs) as I knew I'd listen to far more music without valves burning away. My SETs used 300B, 845 and PX-25 output tubes and they sounded very good for certain types of music.
I home tried (with demo units or my own purchases) many SS amps including Class A, AB and D in the £4-8K range. I found that none bettered the modest NAD M32 integrated, but I now have the latest M33. Most were power amps though some were integrated or all-in-ones. The M33 uses Purifi technology, the latest and probably the best Class D available now. Since I purchased, it’s been showered with Stereophile and other awards. Worth a trial anyway, despite its low price in relation to your speakers, or even mine. I’m sure you could do better and probably your MLs will do just that, but the ML 5805 was slightly lacking in the goosebump presentation that I look for in an amp. Peter
THose 833s you sold would have worked very well I think.Thanks again Peter, that‘s opened the options list. The Benchmark AHB2 is interesting as is the new JBL class G.
AG‘s arrived on Monday, early observations are very tight tuneful bass, but haven’t yet managed to get the sound stage focus that I get with Focal‘s, though I spent a long time getting those right before I was happy. There’s also a hardness at some frequencies, typically vocals, which is more apparent as the volume increases, though I’m thinking this is down the electronics, which were chosen to match the Focal’s.
