Select at album and add it to your queue.Was it established that one cannot a Qobuz album to favorites from within TAS? If that isn’t true can someone explain how it is done.
I have chosen Beatles Abbey Road in this example.
Click the 3 vertical dots at the right of the track to open the drop down menu.
Select "More"
A drop down list will appear on the left pane in TAS.
Select "On Qobuz" at the bottom of the list.
A new drop down list will appear.
Select "Manage Favourites" at the top of the list.
Select the middle one.
What I have been doing is going into Roon and adding it there and then rescanning my TAS library. Doing that results in the album appearing everywhere.
I haven't used Roon since TAS but this method adds the album to Qobuz in the app which I use for search sometimes both on my laptop and iPhone.Thanks for this.
That worked and added the album to my Qobuz favorites in TAS but it doesn't seem to add it to Qobuz's database. When I go into Roon that album doesn't appear. Is that your experience as well (assuming you have Roon)?
I have it connected. It works well, playing music using our USB card right now. I will leave it running over the weekend and have a serious listen next week.
just wanted to follow up on my earlier question about playlist length. i have a tidal playlist that is 1100 tracks long roughly and i keep adding to it. via TAS only 537 items are displaying. i google'd around and there seems to be a squeezebox setting to manually set a max playlist size. i logged into squeezebox but didn't see that in settings. any ideas?
settings > advanced > performance
see link below
Playlist limit - Squeezebox : Community : Forums
Color Touch Screen Puts Music at Your Fingertipsforums.slimdevices.com
Can you show a screenshot? I don’t see “advanced” under “settings”.
Do you mean “server settings” / “performance” / Maximum playlist length?
I thought playlist length is now predetermined as to how much can be cached for the batch player. I thought it was 20-30 minutes or am I wrong
i think thats the play queue. the playlist itself is from tidalI thought playlist length is now predetermined as to how much can be cached for the batch player. I thought it was 20-30 minutes or am I wrong
@Skanda , you can find that in your TAS remote, not in the squeezebox portal.
