I bet they sound better in those colours/colors!
First question. It typically does. Second question. Yes. Not to be pretentious but I believe most experienced listeners would agree. Neither is better. That's for each person to decide.here’s a question... does mid-bass ‘hump’ mask transparency? If you flattened the hump, does the apparent transparency increase? and the corollary? (Asked somewhat tongue in cheek)
Dave Wilson was notorious for using cheap Parasound amps or iPods under a curtain as a parlour trick for audiophiles.this brings me to my "good problem to have". i have spent so much time on my digital front end (and it's still not nearly as much time as others have spent) that i really don't know what limitations i was hearing due to roon + an okay endpoint (linn dsm in the case of the alexx v) vs. the speaker. this is why i'm being more critical of the upstream gear and less of the speaker. i have kept a large thread here on my taiko extreme and today there were two important updates: the new usb card, and tas (their alternative to roon). the combination of the two allows my s5mk2 to image like the big wilsons...but better. it allows them to be more dynamic. the bass frequencies got cleaner and i was pushing my speakers at 20% above the normal volume i listen at and didnt feel it was "too loud" or sharp. the stage, depth, presence, flow, whatever you want to call it is all there and it truly sounds like a new speaker. that's where at the demo i was left wondering how these two beasts (particularly the alexx as the xvx makes no sense for my room and/or budget - "nobody pays retail" better be true LOL) would sound on my gear. i suspect they would be able to push forward beyong the s5mk2 and retain that nice driving bass line i heard. i'm very intrigued by this possibility but it's also worth pointing out that the taiko is just so far ahead of these other digital products that i just dont feel i heard all of what these speakers are capable of.
Never heard of this before. Sounds like a laugh. Are you suggesting that I'm overthinking the electronics in these setups?Dave Wilson was notorious for using cheap Parasound amps or iPods under a curtain as a parlour trick for audiophiles.
the alexx v wasnt fully broken in and was being run on spectral with a linn digital front end. i heard sharpness and grain which i attribute to spectral being ruthless and linn being tipped up. i just couldnt get as agressive with the volume control as i wanted. however, at lower volumes the speaker was doing a great job on all the usual fronts. the speakers were still on casters so that + being used to sealed cabinet bass took some adjustment. overall, i really enjoyed my listen but couldn't help but think that my electronics on that speaker would be much better (for me/to me)
I'm keen to learn if there are changes to the Sensitivity and Nominal Impedance of the new V. The original Alexx is 91dB with 1.5 ohms minimum, 4 ohms nominal..
Thanks for sharing. However, I think this goes to illustrate the important of the source. In this case of all Spectral top of the line system. Their SV CD player would have been a better choice. In terms of system synergy.the alexx v wasnt fully broken in and was being run on spectral with a linn digital front end. i heard sharpness and grain which i attribute to spectral being ruthless and linn being tipped up. i just couldnt get as agressive with the volume control as i wanted. however, at lower volumes the speaker was doing a great job on all the usual fronts. the speakers were still on casters so that + being used to sealed cabinet bass took some adjustment. overall, i really enjoyed my listen but couldn't help but think that my electronics on that speaker would be much better (for me/to me). so i want to stress that there are lots of things going on here but i did like the speaker and it put a smile on my face and i was toe tapping...i dont want anyone thinking the new wilson is harsh etc - it's not.
Why not? 2 out of the 3 Spectral dealers in the US are also Wilson Dealers.I'd be curious to learn what amp and preamp were used for the Alexx V rollout at other dealers. D'Agostino is what Wilson often uses at shows. I would not make a buying decision based on hearing the Alexx V with Spectral electronics.
one man's "warmth" is another man's distortion.Why not? 2 out of the 3 Spectral dealers in the US are also Wilson Dealers.
I'd think the newer Wilsons would give you more resolution with Spectral than other amplifiers.
Subjectively, people may not like it. But, one man's "warmth" is another man's distortion.
Spectral is a system approach. As I've said to @Skanda I'd think his impression would be different if SV CD player was used in a Spectral system with the Alexx V or any other Wilson at Innovative for that matter.
Spectral +YG AcousticsI'm looking for neither warmth nor Spectral.
What's in your system?
I'm wondering if anyone has had longevity issues with the carpetish covering around the drivers.
I wish wilson would change it up some how. With the covers on these models look great but they are somewhat ugly (not enough to not buy them) without. I look at a magico m series or even a series and it's so much sleeker for the viewer. I do like the wilson shape tho.
