What I mean, GG top and side plate are made of copper, not painted. Looks like all pacific top plates are painted in different colours.Hm...i would say they are close - gg, trp, b3 copper top is maybe a bit “lighter” in color then Pac copper top
I have a balanced Pacific, currently running KR-242 output tubes (my favorite in the Pacific). My system is balanced throughout. One thing, I recommend getting the direct output Pacific without the built-in volume controller with which the higher gain of the 242 tubes is a perfect match.Hi guys, I have a newbie question,
Is there any sound difference between the pacific single ended and the balanced one? the tube change is more noticeable in the single ended than the balanced one, maybe?
But those figures depend vastly on the (gain of the) tubes used, rigt?The VLC in the pac is not normally used for full vol control. The active pre does that. The VC is to adjust the output for digital to get the pre in its sweetspot. Normally -8db to -18db.
This looks like you are in the privileged position to try and find out@abeidrov
Taking this in consideration , are you of the opinion that the Pacific DAC with volume control connected to "Direct in" rca in my Crossfire ( in this connection this is just a power amp ) will be better choice than the DAC without VC connected to Crossfire as an integrated ie with pre section and volume control ?
To check this option I should ask Lukasz to install VC in my Pacific cause untill now I assumed that the pure DAC is all I need. But if the VC in my Pacific will make possbile to use 242 tubes I could be tempted .The test I made some time ago showed too much gain but very good sonics of KR 242.This looks like you are in the privileged position to try and find out![]()
I think it really depends on a quality of Pacific VC vs your Crossfire VC, assuming your Crossfire preamp is not overloaded when connected to a Pacific without VC.@abeidrov
Taking this in consideration , are you of the opinion that the Pacific DAC with volume control connected to "Direct in" rca in my Crossfire ( in this connection this is just a power amp ) will be a better choice than the DAC without VC connected to Crossfire as an integrated ie with pre section and volume control ?
Hi Will,A couple of newbie Pacific questions as I am sight impaired and can't go back and reread the thread for answers.
Is there a trick to getting the plastic fuse container out of the back? I can get it to come 3/4's of the way out and then it will not allow me to pull out any farther. I was going to put a different fuse in it.
If I use the remote or the front underneath button to turn it off, is it totally turned off despite the back power switch still being on? There is not a convenient way for me to turn off the back power switch.
Thx Golum...Pacific is still breaking in. I also have the fuse container figured out. It does not pull out totally like all of my other components. There is a catch that stops it. There are two fuses (one a spare). I needed a tiny screwdriver to push the fuse down and out. I then popped the new fuse in from the bottom.Hi Will,
I hope you’re enjoying your Pac.
On/off button on the front of the unit is actually Standby button and it has the same function as the on/off button on the remote control. With this one unit goes into standby mode meaning tube part is turned off while i believe digital part is ON and some other settings are kept from last listening session like VC level. With master switch at the back, all is turned off.
Fuse holder is a bit finicky and it does not go out easily afaik - i only played once with it to change the fuse so can’t really remember what i did.
Take care,
G
Has anyone got any experience with the Lampi reference preamp at all?Thx Golum...Pacific is still breaking in. I also have the fuse container figured out. It does not pull out totally like all of my other components. There is a catch that stops it. There are two fuses (one a spare). I needed a tiny screwdriver to push the fuse down and out. I then popped the new fuse in from the bottom.
Wouldn't it have made more sense to first fully break-in the Pacific and only then after really getting acquainted properly with your Pacific, change to another fuse?Thx Golum...Pacific is still breaking in. I also have the fuse container figured out. It does not pull out totally like all of my other components. There is a catch that stops it. There are two fuses (one a spare). I needed a tiny screwdriver to push the fuse down and out. I then popped the new fuse in from the bottom.
No, sorry.Has anyone got any experience with the Lampi reference preamp at all?
Christoph ---you are always the voice of reason and sanity.Wouldn't it have made more sense to first fully break-in the Pacific and only then after really getting acquainted properly with your Pacific, change to another fuse?
Like this, you can't be sure that the change is also due to more break-in of the Pacific or purely due to another fuse.
What fuse did you insert anywas?
