Here’s a nice bit of info on the EMIA from right here on WBF https://www.whatsbestforum.com/threads/emia-lr-phono-corrector-review.30127/
No Ron. I am only using one phono preamp now so no need for switching box.Hello Tang,
Did you ever find a very high-quality switcher box?
I do agree with MikeL's sonic perfectionist point. So maybe the middle path is to accept a tiny sonic penalty and use an intermediate pair of short and easily accessible interconnects, swapping between or among phono cables on a short interconnect extension, rather than unplugging and plugging directly into the back of the phono stage box?
Esoteric makes nice products. I almost bought the C-03 preamp. Part of me wishes I would have. I really liked the adjustable gain on that preamp. I hope it is a pleasant audition.Esoteric E-02 - 3 inputs, 1 x XLR and 2 x RCA - remembers settings for each input. XLR or rca output must be selected, so can't use simultaneously, which is a pity.
I will hopefully have a listen to it at home in afew weeks.
Were you able to get a demo Phonolab to try as well? That would be a very interesting comparo...Esoteric E-02 - 3 inputs, 1 x XLR and 2 x RCA - remembers settings for each input. XLR or rca output must be selected, so can't use simultaneously, which is a pity.
Hi Solypsa,Were you able to get a demo Phonolab to try as well? That would be a very interesting comparo...
The Thoress phono enhancer has multiple inputs and you can specify the loading you require. I have posted (what's the best phono stage) the latest manual from Rienhart that is, in my opinion, one of the best instruction manuals i have read. I do not own a Thoress (yet) but have been talking to Reinhart about his EQ settings etc.I have used my Audio Research Phone 2 ref phonostage for a number of years but as I consider adding another arm to my Avid Acutus and possibly a new TT with one or two arms I might wish to trade in my AR for one with multiple inputs. Don't really want to roll phonostages! What good phonostages have 3-4 (all MC) inputs? Can be a combination of rca and XLR inputs.
You guys with multiple TTs. What do you do?
Thanks
Yes you can! In truth it never occurred to me to do this so have not tried it yet. I did confirm with Mr. Fehlauer @ Audiospecials directly about it.... One questions - are the rca and xlr outputs on simultaneously? I like this option with my Accuphase as I can use both outputs with different cables to provide a slightly different sound by selecting different inputs.
Each Phonolab has both xlr and rca outputs, which we now know can be used simultaneously, so a 'Quadriga' ( double Phonolabs on one powersupply giving four phono inputs ) will have 4 total outputs two from one selected input and two from another selected input. Make sense?
Yep...each phonolab is two preamps that route to an ( but with two types) output. So with a quad setup will have two inputs selectable on one ( xlr+rca ) out, ditto for the second unit...Makes total sense, thanks. So you need a minimum 2 output cables to run the 4 inputs thou?
Cheers
