It will also allow me to control the volume with TASNot yet. Waiting for a USB/AES converter which will be here Monday. I can't run the TAS driver without it.
Wow.It will also allow me to control the volume with TAS
Does anyone else have this issue? My non-Latin alphabet songs (korean, Japanese, Chinese) are not showing up in TAS. asking cos you’re also listening to korean...I'm digital products seller in Korea.
I think I have many knowledge about digital, but by TAS I realized digital world have new area.
SGM Extreme is no rival music server in the world, but Extreme's real perfect quality was not shown by now.
TAS made SGM Extreme be much more perfect and changed my entire system.
I knew software is important for music server, but TAS' role was too much greater than thing I thought.
Emile's hardware quality is the most perfect but Edward's TAS team is same to hardware.
Emile and Edward said official TAS will be much more greater.
I found one TAS weak point, but no need to mention it.
SGM Extreme's limitation doesn't seem to be existed.
Agree, guys??
If you tap on the three vertical dots on the upper right side of the app and then select Server Settings, the first item under Basic settings is language. The bottom two items in the language list might be helpful. Then again, you might not be able to see your english titles.Does anyone else have this issue? My non-Latin alphabet songs (korean, Japanese, Chinese) are not showing up in TAS. asking cos you’re also listening to korean...
Many Thanks for the detailed report of your careful testI remember Emile and team saying they spent a good amount of effort on making sure TAS was immune (relatively) to network infrastructure/noise and that is proving to be very true.
For example, I think my network is pretty good with a dedicated ATT Fiber line for music, to ONT to EdgeX to M12, all powered by the same LPS. From my EdgeX SFP, I have fiber going to an Optical Module that connects to my MacBook that I use to control music (so not in the direct signal path). That OM is powered by a pilot pro battery. Anytime I have forgotten to unplug the cheap SMPS that charges the battery, I have immediately noticed that something was off and the sound was harsher and noiser than usual. Unplugging the charger from the pilot pro battery immediately fixes the issue. I have been running this network setup for about 8 months and each and every time I have noticed when the SMPS was charging the battery. Crazy to think that I would still hear this noise from behind a fiber line to something that was not even in the direct signal path, but its there and its obvious.
This morning, listening to TAS for about an hour before I noticed my Pilot Pro battery was still being charged by the SMPS but the music still sounded great. No harshness or artifacts that I heard before TAS. I unplugged the charger and the sound did not change!! Repeated the test a few more times and it's safe to say that TAS is doing an incredible job in minimizing network noise for playing back locally stored music, something not even HQP direct (without Roon) was able to do. Still haven’t tested streaming yet so I can’t comment on that.
Hebrog;Anyone using TAS beta with HQP notice an issue with switching tracks in a play queue from different albums with different sampling rates (eg. 44.1kHz to 192kHz)?
The track progress bar advances but there is no sound output.
However, clicking on the next track in the new album will play as usual.
It is almost as if TAS/HQP doesn't sense the initial sampling rate change.
Sound quality is however magnificent as others have reported.
At least now there is a functioning play bar. Never used to move. Now it does. So be patient as stop and fast forward not there yet . There is advance to next track. I’m betting the final release will have these issues resolved.A feature question: is there a means to pause Play in TAS? I only see Stop, and then you must start the track all over again.
And how about FF or Rev? That doesn't seem to be there, either. I've never seen these features missing in a player before.
The buffer is probably set to 4,096, so assuming your input is correctly set, as suggested as I suspect you hear the 192K files, then manually change the buffer to 2,048.
Hi StreamFidelityThe buffer of 4,096 has a high latency of 92.88 ms (1000/44100*4096) with Red Book. At 2,048 it is half: 46.44 ms (1000/44100 * 2048).
Hi-Res with 192kHz only has a low latency of 10.67 ms (1000/19200*2048) with the proposed 2,048 buffer. This is a good choice.
In my opinion, low latencies have a positive effect on the sound. I personally prefer a latency of 1.18 ms. This is the maximum possible setting in the T + A USB driver (I'm not a Taiko Extreme user).
