Blanket assertion. Mike Moffat appears to think otherwise.
Obviously you have not paid attention to my posts -- why would you, since you dismiss the technical performance of the Yggy anyway, whereas I appreciate the one of dCS DACs (how all the technical performance correlates with sonics is a different matter). The zero-crossing distortion of the first generation Yggy is already negligible (the graph in Stereophile is at -90 dB), and in version 2 it appears to be basically eliminated:
Oops, sorry about that! The red does look identical (at least I'm still able to read graphs, if apparently not writing). And you're right, of course, that's the part I found troubling looking at the graphs in the first place.
While this is one of the best waveform reconstruction measurements I've seen (along with dCS, MSB and a handful others), and even though I'd insist it's one of the few measurements that won't merely point to potential flaws (there's at least a morsel of positive correlation), byno stretch of the imagination does it tell us how a DAC sounds, I mean, without undue sarcasm, check these out:
Here is the same -90 db measurement of the MSB Analog DAC (granted, not one of the newest generation MSB DACs):
I guess even the Yggy version 1 didn't compare unfavorably to this one, and the Yggy 2 looks definitely better than this (see above). As I perceive it, the Yggy 2 comes relatively much closer to the Weiss measurements.
I guess the problem is in the realm of SOTA DACs, those graphs all look impressive, and yet people love the one and hate the other, so much for the relevance of measurements…
The first measurement is from the Weiss DAC202 (you posted that above as well), and given your tastes I am sure you liked the dCS Delius (second measurement) much better. Can you describe the sound differences in more detail, David?
While I love measuring things it many times misleads is to false conclusion. Having extremely low distortions to some makes for a dry sound .
jitter in its many many forms is a factual measurement can be directly correlated to better sound. but to add a little confusion how do you guys feel about playback formats.
same files be it red book or hi Rez. flac to AIFF
and of course flac no compression even add in wav. But I’m not a big wav fan.
any ideals on any of the formats. I’m curious in it’s observations.
Huge, holographic 3-D sound stage, lifelike, dynamic and engaging sound with truly wide-band bass and treble extension, digititis-free without any "softness", instead an in-your-face "You Are There" kind of realism, with in absolute terms (not compared to other DACs of the same era, but e.g. the owner's opera singer wife who was not only present in recording, but also in person) a slightly "ghostly" lack of density or palpability and barely noticeable grain (at realistic playback levels, near-impossible to hear any grain at more moderate levels) on the one hand, a flat (dynamically as well as in terms of soundstage height or size), clinical, lifeless, downright boring if not depressing presentation on the other hand. This was the first of a whole series of DAC comparisons I wrote about in parts on these forums at one point, in the course of which the Weiss owner relegated the DAC202 to his holiday cottage.
