Yours is a bit of a dream system, (perhaps two). I thought I would send along this video of a full Destination System which is similar but different. Important to note that I am in the trade and distribute Destination Audio in the US. (I have written WBF on how to notate my membership as 'trade' but as yet haven't heard back.)
I had posted these photos in the Io phono stage forum, but they should be over here too.Cary Audio CAD-1610-SE monoblocks and Von Schweikert VR-9SE MkII. Cary's use the KR Audio 1610 tube, almost as big as a wine bottle. They produce a constant heat, or no, I meant 55 watts RMS. The amps have been tweaked with Teflon coupling caps, hexfred rectifiers, and upgraded cables for power and signal between the two decks. Have had these amps for over 20 years.
www.clarinetaudio.com
Are those Yamamoto footers or perhaps Shun Mook? Can you comment on how they changed the sound at all? Many thanks. David Whistance
Nice Dynamikks 8.12 monitors! I have the current Athos 10 as one of my speaker systems. My colleague has the big 12.18 monitor.Great gear presented in this thread, I noticed so far. I was a little active in the Lampizator Golden Atlantic TRP thread, so here is my listening room around the Silvercore TB3/1000 SET amps with a Valvet Soulshine 2 MK2 preamp:
Agree, the Athos 10&12 are more the successor of the old Monitor series and they are very SET friendly!Now this is a speaker I am very interested in - every coax based speaker I have heard has nailed the tweeter/midrange balance better than any other box speaker I have listened to. Look forward to reading a review of the Athos...
Thank you, I've been intending to try them for ages. I'll send off for some ready for the New Year.Yamamoto, quite a few. I am using them in different systems since they are available. Works well, gives a bit more air, than without them just using the glass shelves under the electronics.
Advice: do not push them to their limit. Use them only up to 50-60% of it. Will work much better this way.Thank you, I've been intending to try them for ages. I'll send off for some ready for the New Year.
Usually you don't want to use more than about 20-25% of full power, so as to avoid the distortion that causes any SET to sound 'dynamic'.Advice: do not push them to their limit. Use them only up to 50-60% of it. Will work much better this way.
