Dear Sir,
Please try and focus on the performance?
Kindest regards,G.
So this is a different video from the on Tang posted... both sound pretty good to me. I like the woodwinds a lot. It sounds like a decent classical recording. Most modern ones are free of distortion but sound thin and the vintage era ones sound compromised by the hardware but otherwise well executed. Given that we don't have that much to choose from on vinyl (i.e. we're mostly limited to recordings that are decades old) it's nice to have a (in theory) the best of both worlds.
Thank you Andro. I am still skeptical if I should accept the first half of compliment.Sounds good/ natural tang , and it looks great with the wood diffusors and the rest in black .
I think the LAMMs deserve to be in the spotlight .
I still have an itch on how the ML 3 / LL 1 combo would sound on my speakers and how 32 watts would drive them![]()
Makes me wonder what’s up with those who said the recording was boring or poor.
So tang whatsapped me this yesterday and I have listened to it repeatedly, because I can't get enough of it. The system and the bass section and the excitement is off the charts. I can just see why Mike started off on this, as his linearity to 5 Hz in that awesome room will also be off the charts
I have only heard this recording before in Mani's second system where it did not breathe and sounded compressed, but as that was his small system I thought that could have been a system compromise and would like to hear it elsewhere. I didn't find it harsh or thin there at all though.
On Tang's video, it is fabulous. Sure, everyone can want a little bit of this or that every recording, but rarely is it that the holistic realism is so high. This just swings. Look at the suspense and the range of the orchestra.
That said, Tang's ears are still in question because I tried listening to it on the mobile like he does and it sounds harsh, shrill, and thin.
I was waiting for him to upload but since he didn't I thought I would do it myself to say how good it sounds and that you cannot listen on a mobile
Sure .Thank you Andro. I am still skeptical if I should accept the first half of compliment.
The ML3 should be great for any higher efficiency speakers. It reproduces the sound of acoustic instruments superbly with exceptional differentiation. There is this different tonal dimension and contrast of instrument with clear air(air air air air air air...just to bug Folsom.) around that make what you listen to less homogeneous. I think if you could get the whole system chain from front to speakers less homogenous even simple music becomes interesting. I find the transparency of ML3 is uncanny with the Telefunken 12AX7. In other people's system, the Lamm could be dead quiet. But in mine I could still hear small tube artifacts and some time small hum if I put my ear close to the drivers. I had ground loop problem so I cheated solving problem by taking out ground leg of the power cords. So my system is not dead quiet like other people claimed theirs. But it is quiet enough to not distract me during listening. A second hand Lamm could come at a great price. I highly recommend anyone with higher efficiency speakers. You also don't need to get the ML3 if budget not allowed. The ML2 is also great. Much cheaper too. Used ones offer such great great value. I think ddk likes the ML2 first version very very much.
Thanks for showing the video of your system in another thread. It would be great if you could show a video playing tape in your room. Ked and I have no problem if you post it in this thread or in the what you think of this video thread.
Kind regards,
Tang
Interesting, since you can get a used pair of ML2.1 for <$10,000 USD. Thanks for putting this one on my radar.Thank you Andro. I am still skeptical if I should accept the first half of compliment.
Kind regards,
Tang
At one point I did some research on the ML2 and learned that what you really want is ML2.0; the subsequent releases are not as good.Interesting, since you can get a used pair of ML2.1 for <$10,000 USD. Thanks for putting this one on my radar.
Noted. Thank you.At one point I did some research on the ML2 and learned that what you really want is ML2.0; the subsequent releases are not as good.
By the way, I agree with those who insist that you need to listen over headphones in order to get any idea of the sound, insofar that is possible over a video with AAC or MP3 compressed digital sound.
Listening over computer speakers or even worse, a mobile phone, doesn't cut it.
I listen with a slew of things depending on the time of day. And I have to say even on phone a LOT of character still transfers over.
They’re basically the same amplifier and aside from a few nuances they sound equally good too.I’ve discussed this with Mr Lamm and he said there is little difference between the ML2 and 2.1 other than upgraded binding posts and a few parts. He said they sound identical.
Maybe @ddk can weight into this.
