It's hdmi cable format.Hi I'm looking for I2S recommendations maybe under 500 USD. Not huge fan on Audioquest. Was thinking Phasure may be a good option but would love to hear some suggestions. Using for Rockna Wavelight Server to Wavelight DAC. Ideally <1m. Thanks.
Just contacted him on audio gon. Any prior experience with his cables sir.Revelation Audio Labs advertising on A'gon. He is asking $700 for the 1.25m length but if my experience is any indicator, he'll accept an offer closer to your budget @jfx
Guys I'm leaning towards the Tubulus Argentus HDMI any impressions from that manufacturer? The Phasure looks good too. Any inputs and personal experiences are highly welcomed and thank you so much.
Not sure if this helps, but I purchased a tubulus phono/power supply umbilical which was custom made for me.
Both cable and service was excellent and a definite upgrade, so I can recommend the company to you at least.
good luck with your search
I'm in the same boat, need a good HDMI cable between my DCC and PS Audio DSD.
There are RAL, Phasure & Tubulus, any suggestion and experience please?
Thx MTB Vince, I heard about that about RAL from afew forums, that's bit worry.Can't speak to the latter two products but my RAL I2S (HDMI) cable sounds great between the Jay's CDT2 and the DSD. Don't expect speedy delivery of this handmade cable though... Or a snug fit in component jacks.
Thx ag3, I read your impression of RAL & Tubulus, it's literally the only review I could find online of the comparison. I totally trust your first hand info. Not sure if your Tubulus has improved after the burn in?I can recommend both RAL and Tubulus. See my post above. RAL for more detail, Tubulus for more bottom end and fullness.
I actually didn't have too many issues with the RAL delivery .. took him a few days longer to ship than he had said. (Tip .. when asking for an update email .. tell him you're looking to grab more alot more cables from him .. leverage).
Honestly Phazure has paragraphs of writing but I'm simple, I just want silver conductor (4N+) a decent gauge and good connects. And I can't find that on their product page so not interested.
I'm totally with your for the RAL & Tubulus result, also the Phasure cable material non silver item. Actually after their tech read I don't even know what material it uses, guess its copper.
The 3 cable are all in my price range, I just want to buy one and it's troubling![]()
