Center Stage 2
cat6man
913
1,050
1,185
west of NYC, east of SF
is there any synergy or contraindication adding Daiza platform between centerstage2 and existing shelving?
Good question as I don't know the answer except to say they might be competing technologies and self defeating to use both
For me I would use one or the other. Joe, the manufacturer always states that all existing tweaks should be removed before using Center Stage
PeterA
12,669
10,942
3,515
USA
Steve, don’t people use Critical Mass racks in conjunction with the footers? What shelf material is most recommended for these footers Or can it be anything that is stable and solid?
hi Peter. Indeed people use centerstage feet on critical mass systems racks. I have said before that using centerstage feet on these racks elevates the shelf one model higher. In other words if you have centerstage feet sitting on black diamond shelves it virtually elevates the rack and shelf to the Maxxum series. So also if the feet are sitting on maxxum shelves this elevates the shelf to the level of Olympus. This has been mentioned many times. The feet and shelves work the same. I can’t say that for CS plus Daiza as I just don’t know but think it unlikely. Hence not sure If benefit would be derived
AFAIK Peter, Joe has tested the feet on most materials but not sure if he used Panzerholz The way the Daiza is designed is a totally different principle. only Way to know is to listen first without feet or Daiza. Then Daiza alone. Then CS alone. Then CS plus Daiza together.
Reactions: PeterA
heebrog
131
51
135
Perth, WA
Except the re-settling time makes these comparisons very difficult to do.
XV-1
3,619
2,629
1,860
Sydney
Centre Stage 3 out yet?
PeterA
12,669
10,942
3,515
USA
Resettling with CS2 is much quicker
I have spoken to people who followed the strict 10 day settling period. They followed the prescribed process, did their evaluations, heard what they heard and then switched over to more rapid A/B testing and heard the same or very similar results. Perhaps after the initial settling period the footers require less time to return to a “good” state.
Is this settling process well understood?
The feet are patented and work according to the Second Law of Thermodynamics.So understanding that helps to understand the settle in The initial version 1 took 10-21 days to settle in. Joe changed a few things on the CS2 and everyone commented that the settle in process was much quicker. In fact the 1.5's settle in 3-5 days.The analogy Joe would tell us regarding the feet is that it is like dumping your garbage from the house and leaving it out by the street for pickup
The other noticeable finding was that if the feet are removed from a system and then put back in as in an A-B-A test resetting happens much more quickly for reasons I am unable to explain
bazelio
2,494
1,748
345
California
I'm in the (apparent?) minority who encountered minimal change to the effect produced by CS2 1.0 footers over the course of the prescribed break-in period. I placed them under a heavy amp, a much lighter phono stage, and it's PSU that falls somewhere in between. When I AB'd CS2 vs direct-on-rack at time 0 then again at time 14 days, the delta was roughly the same or at least more nuanced than my medium term audio memory.
I would have used 1.5's under your heavy amp and 0.8's under the lighter equipment
bazelio
2,494
1,748
345
California
Interesting. Joe once said they aren't weight dependent and improve as you go up. My amp is only 65 or 70ish pounds.
I would have done your phonostage and preamp first before I even considered the amps and power supplies.
Hieukm
271
105
128
Hi Steve and Joe, i have just purchased 2 set of CS 2 1.5 for my Thrax mono amps which has 4 big rubber feet under each foot which leave just enough space for 4 CS2 1.5 underneath but very close to each other. I want to ask is there a minimum distance requirement for each feet? Putting the CS2 1.5 underneath the rubber feet gonna reduce the effectiveness of the feet?
First off congrats on your purchase bt a few things
1. The Center Stage feet are never placed under the stock feet but rather somewhere around each stock foot
2.I am not too familiar with Thrax amps but a few points
The 1.5's are designed for large and very heavy components such as amplifiers over 100 pounds but certainly a stock foot of over 1.0 inch in height would mandate 1.5's being used however my guess is that a set of 1.5's are just too big for your amp.
I would have suggested you consider using 1.0's and not 1.5's and impossible to remove the large rubber stock feet
HTH
Hieukm
271
105
128
HTH
I can put the CS2 feet around the stock feet but very close to each other. Is that gonna reduce the 1.5 effectiveness?
My mono is 140 pounds each then the 1.0 is good enough?
