Agreed with DIY, you can get great bang for your $ but IME it also only goes so far. I haven't heard any SOTA components that are DIY. BTW, I thought seriously about either a Technics redo with a DIY Panzerholtz plinth or a Teres TT.
Isn't Lampi in effect the world's greatest DIY product? Not that the customer puts it together, but it's origins and ethos as time goes on?Agreed with DIY, you can get great bang for your $ but IME it also only goes so far. I haven't heard any SOTA components that are DIY. BTW, I thought seriously about either a Technics redo with a DIY Panzerholtz plinth or a Teres TT.
Watch out Marc, i have the image of cult members with pitchforks in mind right nowIsn't Lampi in effect the world's greatest DIY product? Not that the customer puts it together, but it's origins and ethos as time goes on?
I don't know any of the parts your using. But I bet what your doing sounds good for the effort.Ok well you can usually pick up a JVC QL 5/7 on eBay for $300-500 (there are some currently on there)
Turntable $300-500
Cork piece to put on top of the rubber mat $8-12
Sumiko Pearl with shim mod and a tiny piece of clay in the stylus gap $120
Non-hardening clay 4.5lbs $25
Screws $5
Belden 8402 IC's $80~ eBay (only necessary if we need a phono preamp to preamp IC for this to be complete list)
That leaves $263-463~ to build a Salas phono preamp. ($60 for PCB, $64 mini kit, $10 matched transistors, $8 PRP resistors, $30 PSU boards, C7 $24, $100 enclosure, $50 for chassis stuff)
$838-1088 depending on a little this and that, price of TT.
You put screws into the bottom side of the TT and pack it with clay to add some mass. This setup will blow away most people if setup well. (knowing how to setup a cart, and knowing when to add a little extra overhang for example, like necessary on some cart/arm combos)
If you want to upgrade later a new plinth for the TT is a nice idea. Some people prefer this TT over ones they've had for huge sums of money, once it's in a heavy plinth. I think it's better if you plug it into a little bit of a filter and change the power cable ($100).
One of the most cost effective sources is a highend FM tuner like the Magnum Dynalabs, particularly the 109T. Obviously. it only makes sense if you have access to good quality FM stations as we do in the UK, notably the BBC and Classic FM. Their classical programming is outstanding and Radio 2 has some good programmes of earlier rock and pop music eras.
My 109T gets switched on when I get up and is on most of the day and a fair bit in the evenings.
Good used 109s come up for sale qute regularly at around £4k and if mated with a good external roof mounted aerial they deliver top class sound. You can, as I am doing, improve them further by replacing the stock valves with better NOS valves at around $300 a pair.
I think I am in something of a minority, but if you have access to good broadcasts an FM tuner is a very cost effective buy.
OK, we can also apply DIY to digital - you can get great kits to assemble at less than $1k, fit a few exotic components costing about the same, some silver wire and you immediately have a DAC that "kills" all the competition.
DIY products are unique, listened mainly by their creators/builders, and can not be compared with commonly available products. But I really appreciate diyaudio.com and lencoheaven.com and I think that audio DIY is a great hobby - I have considered going this way several times in the last years, as I have built a lot of equipment in my twenties, but lack of free time kept me away of it.
I'm aware of some very good DACs that toast analog, but I guess different strokes. For example I'd take the TotalDAC TD12 over just about every analog I've heard except a few >$50K setups. I bet if you AB'd blindfolded you'd change your mind..
And your love of owning and trying all that exotic and expensive equipment Francisco![]()
I think the problem is it depends what you're listening for, and for me digital cannot yet compete for what I enjoy. Some day I'll work on designing a DAC to like digital more.
Really. Now your DAC expert and with a little clay going to outclass all the others in production. Come on. Comments like this give me pause to believe other statements.
The JVC table seems to have a lot of followers. It may be a good under represented secret. I was reading something about servo arms on certain models that fail. Is there anyone who can fix it?? Can you get parts? But i guess for $300 you use it for parts and get another.
Your comment can very well be taken you believe you can build a better dac than anyone else out there. That would make you an expert.
If you don't understand a facetious comment about clay then you missed the point.
To be clear, you hot rodded an existing TT. You had nothing to do with the design and build. Lots of guys on Audiokarma are taking about the mods you did. They are nothing new. Same as people taking production burr brown dac chips and feeding then good power in a nice case, getting decent resuts. That is how many great designers started 20 years ago.
I find it interesting almost noone commented on R2R. It may be the best source >$10K from what I've seen in terms of a used deck in very good shape + a head preamp.
