Network Improvements and their Impact on Sound Quality
heebrog
131
51
135
Perth, WA
Thank you. From where I was at I feel very fortunate. I'm sure you can take anyone of my X number of devices and swap them out for something else. My gut says at this point, it would be different vs. much of a leap upward.
I could get by with just a few of the devices actually, maybe one. Maybe even with just a dedicated ISP line in and an Edge or a switch. Good cables, grounding, VIBRATION CONTROL all make such easily noticeable improvements that I think you can get very acceptable VERY high level sound from streaming, without breaking the bank.
Sure I went crazy, but the whole network costs about the same as a high end guitar and I have many of them just sitting in their cases:)
Hi Bob,
Can you comment on the impact of your "mega switch combo" on the recent Taiko Extreme ethernet/ROON tweak.
I'm just wondering if the impact is as great as before with local playback and streaming and if the difference is greater with streaming.
Thanks
G
wil
1,524
1,548
428
There's an interesting post from Nenon on Computer Audio:
https://audiophilestyle.com/forums/...f-computer-audio-streaming/page/676/#comments
... where, to paraphrase, he starts to analyze his devotion to network improvements (switches, clockers, cables, and their power supplies) and is concluding that while all of the above have improved the sound to his liking, that they are probably best characterized as "tone controls."
This made me smile as this is exactly how our resident network-tweak-sceptic, Steve, has been characterizing the network changes so many of us have been obsessing over.
Nenon goes on to imply, if I'm reading correctly, that the type of operating system changes Taiko is implementing to improve Roon performance may be more substantive than concentrating on the network.
Reactions: kswanson27
Rhapsody
3,466
6,540
2,535
Brooklyn NY
Rhapsody.Audio
Hi Bob,
Thanks
G
Hi G,
It's so hard for me to give a good opinion. In the last week I inserted the Waversa W router, grounded the two M12s, and grounded the Waversa. With those almost finishing touches (still have the JCAT Gold Sig cables on the way) the system sounded really great to me. I was totally happy with the perfomance.
Then Emile did his magic and the sound took a huge leap regarding vibrancy, incisiveness, resolution, bass performance, micro dynamics etc.
Then a day later the Magico A5s arrived, which sent me into a "tizzy":)
Now, I have no idea of what's doing what to who, other than it sounds REALLY, REALLY GOOD.
Reactions: ctydwn and onsionsi
kswanson27
368
179
128
79
I agree. Assuming i can get the damn Edge RouterX to play nice with my Arris 8200 modem I'm going with a simple, direct fiber network to the Extreme: Dedicated cable coax >Arris 8200 modem > Sablon ethernet > Edgerouter X SFP > 15m fiber > Extreme. Using Finisar SFPs.
Rhapsody
3,466
6,540
2,535
Brooklyn NY
Rhapsody.Audio
You can get GREAT sound with just plugging in the ethernet cable from your ISP, especially with the last Emile update. No need for anything else, unless one wants to experiment and see if it makes a difference to them.
sbo6
1,678
605
480
Round Rock, TX
I can't recall but earlier in this thread a gentleman posted that if you want to know how much the best switch / ethernet isolator / ethernet reclocker can benefit (or not be a detriment) to the sound in your system - disconnect ethernet from your server and play a local file, then plug it back in and see how much of a difference there is. I did such a test and the difference was minimal, maybe even in my head to be frank. So either I have a really good ethernet switch (a stock Netgear with an Acopian gold LPSU) or there really isn't that much to gain IME unless you have significant incoming ethernet noise.
kswanson27
368
179
128
79
Thank you Blackmorec!!! Excellent. It will be interesting to see if the "network interest" from members can transfer over to this thread. Hope so.
I will share where I am with my network discoveries a little later today. I'm very interested in ANY ideas or pointers from those, like yourself, that are further down the road than myself with extracting further sonic performance from my Verizon GPON/modem all the way through to the server. I use the Extreme as my server, BUT also have a Rockna, SGC and Aurender servers as well.
The cool thing is that is if network optimization is found it pretty much (there are probably exceptions) should benefit any server.
Again, thx for starting this thread!
Hope this is posted in the right place. I'm trying to install an Arris 8200SB modem. How do I determine which version it is? I've heard it must be version 4 or higher to work with Spectrum and it is dropping the internet connection every 90 seconds or so.
Rhapsody
3,466
6,540
2,535
Brooklyn NY
Rhapsody.Audio
Hi Ken,
Did you get into the menu of the Arris modem? It's in the user manual on Chapter 5.
https://arris.my.salesforce.com/sfc...h/9Nh17rOX59OqJRfv4_PGHkAjUvwIaGiOxdcQQOp_Tyk
I'm not familiar with the Arris, someone else here might be, but there might be a setting that has to be set in the user interface menu that you access via putting the default LAN IP address, which is 192.168.100.1
Rhapsody
3,466
6,540
2,535
Brooklyn NY
Rhapsody.Audio
Hi Ken,
Ken,
On table 4 of Chapter 5 in the menu there is the version numbers. That should tell you the version you are running.
Jeffy
479
174
348
Orchard Lake, MI
I'm using a Netgear AC1200 wireless router that is connected to my custom switch. Does anyone know of a better wireless router than the Netgear or does it not matter?
auricgoldfinger
120
94
93
auricgoldfinger
120
94
93
Ideally, you want wifi turned off on your router (any router) for best sound quality. Nenon explains the reason and details in a couple of posts earlier in this thread.
Jeffy
479
174
348
Orchard Lake, MI
This is attached to my computer with Jriver for all my music. I need the wireless router so I can access Jriver with my Ipad. With wifi off I would not be able to use the Ipad.
dminches
3,474
2,846
1,410
My suggestion would be to turn off the wireless on your router and get a wireless access point like ubiquiti. The wireless will be better and you are moving the WiFi radio away from your main router.
dminches
3,474
2,846
1,410
The access point provides a wireless gateway to your router. If you ipad can see the access point then it can see everything on your network.
Jeffy
479
174
348
Orchard Lake, MI
My computer is in another room away from my main router. In other wards I can’t connect it directly to my computer. So that is why I access another router in the computer room.
auricgoldfinger
120
94
93
did you search this thread for the posts where Nenon answers your questions?
Thuan
41
19
73
70
I’m not following you. How will my iPad which needs WiFi going to work this way? A router allows you to use WiFi not a switch
You're absolutely right, we all need Wifi to use a control point such as iPad or android tablet for remote or headless playback. What others tried to convey here, to my understanding, is to separate the Wifi functionality from your audio handling router. Let some other device such as another Wifi capable router or an Access Point do that exact task: Access Point. That's what they mean by suggesting you turn off Wifi on your router.
Here's what I'd do, to put it in a simplistic way: connect a non Wifi router to custom switch. If cable lenghth is an issue, consider FMCs. Also to the switch I'd connect a Wifi access point. The custom switch will "buffer" your router from Wifi, I'd get better SQ that way.
Similarly, I've got better SQ when replacing ISP supplied all in one cable modem/wifi router with a pure modem such as SB8200, connecting its output to a pure router, connecting the router to a custom switch, etc. You get the picture.
heebrog
131
51
135
Perth, WA
Hi G,
Hi Rob,
I appreciate the problem with the changing baseline.:p
Would it be convenient enough to just connect Extreme to the Waversa W Router directly; bypassing the two M12's to see if there's a profound drop-off in SQ?
I think the two M12's made a huge improvement in your previous setup especially with the Optimo 3 Duo PS.
Geoff
ps. is the Verizon router still in play?
