Exactly. Whisky seems to work particularly well!So you drink to not notice the tarnish?
Steve, the photos of your Duracell were the inspiration for me to change my order right before shipment from the gold top to the copper. So thanks for that. Always liked the copper top on my GG. Just matches the surroundings better in my case. The GG was manufactured in 2016 and still looked perfect the day I shipped it back to the motherland, even soberI have the Duracell rabbit model myself and there isn’t a mark on it. It just “keeps on going”
Sorry for my OT question here:BTW, I use the RK PX25. The rest of the world is waiting for your assessment of these. The best I’ve tried so far, but haven’t gotten around to the 242 yet.
ChristophSorry for my OT question here:
Have you tried the RK PX25 in your Allnic amps as well?
What PX25 type tubes are used in your Allnic amps as stock?
Btw. I got my Duracell Pacific with the RK PX25 in May over a year ago.
Right this moment I'm listening to it with the RK 242 tubes![]()
https://www.whatsbestforum.com/thre...top-of-the-line-dac.23863/page-53#post-652887Christoph
have you compared the KR242 to the RK-KR242
No reason to try the RK 242 then if the regular 242 matches your system so perfectly.Thats exactly what I have heard others say as well
I love that brute force dynamics and that's why I haven't tried my RK-KR PX25 yet
Have you compared the KR242 to the RK-KR PX25No reason to try the RK 242 then if the regular 242 matches your system so perfectly.
But after you already own the RK PX25 anyways, I think for curiousity reasons alone, I would try the RK PX25, even if it is just to have a slightly different flavour![]()
I’m running regular KR PX25 in the amps. Unfortunately the Pacific is a UX4 base and the amps are UF4 so they aren’t interchangeable, unless I can find adapters. But pursuing this has crossed my mind. The RK PX25 is not available with the UF4 pin out. I have KR 5u4g rectifiers coming in soon. In this case I could swap rectifiers, but would need another RK 5u4g. However, the RK doesn’t fit in the amp chimney. Could just leave it off too.Sorry for my OT question here:
Hm. One day I'll maybe understand why people like the KR 242. The KR PX25 was better and even then it isn't top flight, but it is the best KR I have heard.
I remain baffled.![]()
Does your PAC have the internal output switches to reduce output? Mine does and I run on the lower output setting.
I believe they are now standard. Remove the top cover. There are toggle switches located on the top circuit board, on the back edge close to the output connections.I find this fascinating as I have never heard of these. Where are these switches. Are they standard or only installed upon request
The fact that you don't understand it despite repeatedly stating is the sad part. It didn't work properly in your system and I didn't like it there either. No disagreement. Yet you will continue to state loudly how the tube sucks instead of trying to listen to it in a properly set up condition. The same goes for people who have heard vdh Stradivarius in not proper conditions, it sounds shite, or Marc that day commenting a one off experience where the London Decca is bright and shrill.
To be far to you Ked the reason you like it so much is the heater setting in your DAC is probably bang on correct for the KR 242. And therefore it shines.
