I personally thought the birch horns were beautiful. Welcome @VladB, please start your own thread to show us that awesome system!
Did the price drop when they went to the composite?Birch horns are very difficult and time consuming and labour intensive to make manually. Bill is properly trained in making wooden horns.
The composite material ones can be made multiple in a day
Hello, Tang!
I’ve been a silent participant in the forum so far though much enjoy reading about your adventures in the audio world
I have a somewhat different model of Ralph’s FLH bass-horns - they are wider (around 4.2m in width together) but look to be a bit shallower - I think about 1.3m deep in the center.
I do not think moving them front or back a bit will make a huge impact on the low bass frequencies` Integration with the mid-bass horn, as the LF wave needs space and time to develop in any case, and its front does not end precisely at the horn’s mouth. Especially if you move around your room a bit and do not sit in a single listening position all the time.
This wide dispersion and ability to integrate acoustic space-time and keep an even acoustic energy level at various positions in the listening room (provided you are beyond the minimal HF/MF/mid-bass integration frontier) is one of the key advantages of the horn system.
Remember about the subsonic filter on your bass amps. I much prefer to keep it in “On” position as this cuts the deep bass room resonance in my house quite a bit, clearing up the LF even more.
And a pic of my old school Gamma here - they were made from exquisite birch plywood before Ralph moved to modern hi-tech composite materials
And I have my Border Patrol amp power supplies AND a CD player AND a Rubidium clock just in front of the horns
View media item 399
What, are we banning Huawei too?Vlad, welcome to the horns are best forum.
Everyone has their own views on videos, but if you can, please post some videos playing classical, recorded on Samsung or iPhone.
I hate the warmth thing. Many cartridges and cables and horns have the warmth thing. Imo, the warmth thing always come with the veil and you never get the see through air. I shy away from anything that blur my transparency. When ddk disconnected my back load subs back then he showed me the transparency. And transparency went up further with the introduction of the Lamm gears And Kuro cables. Ddk also wants me to swoosh my Kuro because he believe they are the cause of my sibilance heightening my highs. But I keep using because I haven't found any cable as transparent as these and I am no Mr.Sibilance-Free. One cannot finish his system with just transparency, he needs the musical energy and reach and differentiation and variation. These things come from the Cessaro, the Lamm and of course good vinyls. The American Sound to me is a "nothing"machine that spins vinyls really well. The Emt phono is a handy uncolored box that enable me to connect 4 phono cartridges to it. Now with the new subs. Funny... when I am way into this audio thing deep enough I tend to spend more time lookIng for faults of an equipment more than merits. People do advance their ears. And I very much agree with you that time will tell.it's the whole 'warmth' thing.
fatness in the mid-bass, even if it's feedback resonance, can be musical. it's the opposite of harsh. right now it's an attribute......and part of something new and exciting.
the question is whether it will be limiting to what musical truth is desired down the road?
like Peter A. and his room treatment and vibra-plane. you can like something, and then like something else better. Peter had to try it differently to find out.
time will tell.
Huawei is very color Howie.What, are we banning Huawei too?![]()
Hello Vlad,Hello, Tang!
View media item 399
I think that when we start we are so happy that some equipment 'gives' our music 'more', then as ears (and music collection quality) improve and learn we want our equipment to stop taking so much away... Funny... when I am way into this audio thing deep enough I tend to spend more time lookIng for faults of an equipment more than merits...
Tang![]()
Unfortunately, most likely not an optimal solution...T, check with David, simpler to run a longer sc and have a nice solution, best of luck!it's possible, however remote, that the top of both your bass units are a good place to have your Lamm's. and that somehow hanging them or placing them behind the bass units on stands would not help.......much. those are heavy dense amps and they might be loading that top surface with just the right amount of mass to dampen it effectively......and actually improve the sound.
one way to find out without all the hassle would be to get a resonance measurement device and measure that top plate on the bass units. if they stay calm during vigorous playback then just go with it if the visuals are acceptable. but......if the resonance builds with the music, then that is being added to what you are hearing, and you are leaving musical truth on the table. an investigation is much cheaper than a guess at what might work. and maybe the result will be inconclusive......just a slight amount of effect. and there is no hurry, you are happy.
sometimes we think too much. and all the time we think too much on the forum. what else can we do? i can recall a few times when i was satisfied and many wanted me to try something. it's normal.![]()
Plywood's generally not the ideal material under equipmentUnfortunately, most likely not an optimal solution...T, check with David, simpler to run a longer sc and have a nice solution, best of luck!
vbw,
-a
Plywood's generally not the ideal material under equipment.
david
Tang![]()
