91 dB at 6 ohms -- I would look for a different speaker. 99 dB and a flat impedance which was mentioned by others too. You may get away with 96 dB, depending on how you listen. Consider Daedalus (I have no financial affiliation with Lou).
if you live in Pacific Northwest, I may let you audition my Vaughn Cabernet at your home for 7 days or so.
http://www.stereomojo.com/Onix XCD-50 and XIA160 review/XCD-50ReferenceCDPlayerReview.htm
It may work with your amp in modest size room.
If you like it, then we can negotiate price but it will be within your budget.
I can sell you at 4K$.Those are interesting speakers but my real budget is only $4k!
I will most likely look at Living voice R25A or Avatar R3? Anyone here own Living voice speakers?
Damn that's the biggest crossover I have seen!View attachment 65799
Daedalus crossovers are fundamentally the same for his entire speaker line. Now uses in focused areas Duelund caps. Call Lou or PM me about the speakers. He will know one or two models that best fit your room. Lou also has demo/showpieces that are a great deal. I usually do not buy speakers used but I would Daedalus.
I settled on Daedalus after extensive research. Yes, there are other amazing companies out there. I am always focused on quality, performance and value -- Daedalus is an amazing deal for what you get.
I recommend Lou's speakers to customers worldwide. Shipping overseas is actually very easy and amazing cheap when placed on skids and sent freight. The small and mid-sized easily can be shipped by air.
A few guys I know have or have had various Avatar's and love them. I've heard them in various setups, the best driven by a Dartzeel intergrated.
There's something about their bass that has never worked for me, they've never satisfied. They seem to me to verge on the lightweight/polite. That said what they do they do well so they may work for you.
