So you believe that digital has inherently audible distortion, Tim? ...Of course digital has its distortions. That doesn't mean I can't prefer it. It doesn't even mean that it can't be better
Frank
Myles
But which one do you think has the least amount of distortions? surely not analog as we know it?
Frank
And that is exactly what my point would be; there is nothing in the actual nature of the digital process, as currently implemented in the specification for its capabilities and resolution, including that of Redbook, that SHOULD cause audible distortion ...Yes and no, Frank. No specific distortions I can point to that are in the audible range. But it's not perfect either. Of course it has to be played through a system, and none of them are perfect, so maybe that's the limitation.
Tim
And so are my ears specially sensitive in that region. And I agree 100% that that is where digital replay so often does fall down, over and over again. My point is that this has nothing to do with digital as a process in itself, but because of the implementation. In other words, the DAC and associated electronics of replay are NOT doing their job properly, no matter what the specs and the manufacturers' glossies claim ...My ears are sensitive in the area where digital errs IMHO, eg upper midrange and upper octave brightness. Others don't hear that. God bless them (but I think if audiophiles heard more live music, like written about since the time Villchur, they would too.) Some people seem more sensitive to pitch with analog. Yes, I can hear it on the tape or LP, but I can listen through it
Frank
You know it's always another excuse for digital. Been hearing one after another for 30 years.
I agree, digital should not require excuses: the headache, especially, and literally at times, for listeners, is that you have be fussy, very fussy, and the manufacturers of playback gear are finding it very hard to get that message. As I have said on several occasions, if the sound is only 98% there it can sound hideous, but get that last 2% to snap into place and it's time for jaw-droppingYou know it's always another excuse for digital. Been hearing one after another for 30 years.
I agree, digital should not require excuses: the headache, especially, and literally at times, for listeners, is that you have be fussy, very fussy, and the manufacturers of playback gear are finding it very hard to get that message. As I have said on several occasions, if the sound is only 98% there it can sound hideous, but get that last 2% to snap into place and it's time for jaw-dropping: massive soundstages, tonality to die for, total "life-like presentation", etc.
Life is easier for analogue, tape and vinyl: pretty close will give you a magical experience, but digital will always be an also-ran if only at that same level of refinement ...
Frank
Yep, at times it seems to be just as bad as that -- I get just as frustrated as any of you guys at times trying to work out what's needed to be done to get the sound "right". The thing is, I am able to get it to a level enough times that tells me that everything's OK with digital as a medium. It may not be a 100% perfect requirement, it may in fact need to be at least 99.5% "good", to pull a figure out of the air, but it as sure as hell has to be quite a bit more than analogue -- as a comparison, analogue 90% there will probably give most people most of the good things that people like analogue for ...So Frank, just so I understand.....you are saying that digital is "jaw-dropping" so long as all the planets are in alignment.Perfection is required to get the best out of digital....and you have had this happen how many times
Definitely not a NSW term, have never heard it being used ..... it's all about who needs to prove they have bigger todger (apologies if I'm not allowed to use that word)
Drat!! You managed to pick my green skin, Tim, I did try and hide it ...
But I am impressed ... in that one post you covered a great number of the issues that distinguish well sorted out systems from ones not quite so "well endowed", in a quality of reproduction sense. So my only quibble with your perspective on audio is that you don't care to believe that you can go a step further, and achieve levels of playback as indicated in my earlier post and elsewhere in threads where I participated in my time on this forum.
Frank
The net effect that I seek, that so differs from your expectations of what's possible, is the reason, is the motivation for my continuing on this quest. And the reason why the "on song" element, for me, is so ephemeral is firstly because it is hard to achieve and fragile to maintain, and secondly because I still don't properly understand the mechanisms involved.in fact I suspect your tweaks do more harm than good and that's why you can't seem to get "on song" to last. We reside in completely different dimensions regarding the net effect.
Tim
Possibly true, but instead of it being the biggest todger it may be also viewed from a collection/uniqueness point of view as well, although some would have greater value than others and I do not mean collection as hoping it gains values over the years but possibly similar factors such as who engineered the product, etc.Back on topic:
There is no way anyone needs to spend stratospheric amounts of money on HiFi. Comparisons with cars are just as fatuous because no-one needs to spend that sort of money on cars either.
If we're honest with ourselves we'll admit that beyond a certain level (and that level is not all that high) it's about status. And if we're honest about that, we'll admit that it's all about who needs to prove they have bigger todger (apologies if I'm not allowed to use that word)
If I chose to ease off in my pursuit, instead substituting the ordinary speakers with well regarded audiophile rated items and stopped being fussy about things, then I would end up with a very good system comparable to many others: "good" recordings would sound very impressive, reasonable ones would be quite acceptable and pleasant to listen to, and "bad" recordings would be pretty intolerable. Sound familiar?
