Bayz Audio Counterpoint 2.0 >>>>Rhapsody.Audio
These speakers fascinate me. Can someone explain to me their mode of action
I can Steve.
Being an engineer, I read Zoltan's Ingenious patent before I bought mine. For the bass, the two woofers fire upward and downward into the "C" shaped hollow carbon fibre tube and are offset 180 degrees, which will dramatically increase the bass response, while at the same time cancelling the mechanical artifacts of the drivers. This C shaped tube has two rear firing ports for yet further improved bass response.
Using a 1st order crossover at 2k is where the magic REALLY starts! And where Zoltan's design separates from the all the rest.
Located in the centre front of the speaker, the dual diaphragm Bayz Radial Speaker (BRS) takes over, (which is the subject of his patent)
This ingenious dual membrane driver uses two magnetic gaps, into which the edges of the forward and rear firing cylindrical membranes are suspended. Due to the brilliant geometry (the gaps are 180 degrees apart and perpendicular to the main listening axis) the two membranes are cylindrical and approximately 270 degrees from edge to edge which are joined in the magnetic gap and are essentially pulsing, physically growing in diameter in response to the musical signal input to the magnets. (Did I mention the word ingenious...;-))
What is amazing is the area of these two cylinders is on the order of 50 to 100 times that of a standard 3/4 or 1" tweeter with comparable liner excursion!! Not a Ribbon, not a DD, not anything similar.
FWIW I sold my Rockport Cygnus and bought the Courantes after hearing the bigger Counterpoints at AXPONA.
FINALLY I have uploaded an animation that Zoltan shared with me recently visually describing the BRS for those who are interested.
Here's the link showing the BRS 2.0 diaphragm configuration and movement
https://www.dropbox.com/s/8aza4s0p7314dde/membrane_activemovement_anim_06_1080p_final.mov?dl=0
The Bayz Audio loudspeakers represents a complete re-thinking of traditional speakers by utilizing the patented Bay Radial Speaker (BRS), a unique “radial tweeter” design and the unic low mass cabinet.
The BRS radial tweeter was developed as an idealized way of providing a singular, phase coherent pulse and vanishing distortion much lower than other tweeter designs. The BRS tweeter is actually a cylindrical membrane made from a proprietary ultra-light material which creates sound by pulsating in the direction of radiation.
The custom designed woofer was chosen for its amazing speed and unique magnetics. Both on and off axis frequency response of the BRS Loudspeaker are extremely linear throughout its full 360 degrees of radiation. The upper cut-off frequency of the BRS is 50kHz where the radiation characteristic is still circular. The crossover frequency is over 2kHz , 6dB for the best impulse response. The BRS enclosure is made entirely of carbon fiber lined with a proprietary dampening compound. The air flow inside the box is aerodynamically designed, laminar. Lightweight cabinets do not store energy like high weight MDF boxes.
HF_Polar-Plot_2kHz-42kHz-1.jpg%22%22
Zoltan
Correct me if I'm wrong, but I seem to recall that the forward listening axis corresponds to "-90" on the polar diagram?
Terrific info. Thanks Zoltán, Bob and Kerry
i am fascinated by the design
whst is the sensitivity of the speaker
A quick note: the woofer work in phase; that is, both cones move outward simultaneously. While one cone moves upward, the other cone moves downward. The force cancels but the sound pressure level doubles. That’s one reason why the speakers don’t need spikes: the forces cancel out.
Reactions: infinitely baffled
Thank you. So they are reasonably easy to drive
Best of luck on your speaker Zoltán. Next time I am in NYC I must stop at Rhapsody for a listen
is there anything special in the setup of the speakers
Continued: in practice, the spikes help level the speakers because of uneven floors/carpets and decouple floor vibration going into the speakers., not the other way around.
A quick note about the surreal sound; we’ve become so acclimated to monopole sound from speakers, we think this is normal, it is not. Most musical sources are omni or at least, very wide angle. I speculate that is why so many musicians go crazy for Bayz Audio. The other reason may be the incredible speed as musicians are especially in tune with timing: impulse, decay, speed, and dynamics.
Steve: the impedance is extremely flat from 200Hz on up to 50 kHz with absolutely flat phase. Consequently, the speakers work well with tube or SS.
It need about one meter minimum from the back wall, nothing else special. Of course you should fine the optimal listening place, but very easy to move becouse the low mass.
Thank you, I hope it will be soon, not least because of the virus situation.
