AIR TIGHT ATH-2 Reference SUT
howiebrou
2,857
3,815
1,470
Anybody have experience with this SUT? I am on the lookout for a SUT. It has three inputs so it seems ideal for multiple tonearms. It also has a good range able to match those very low impedance cartridges like the MSL ones.
Input Selector
? position
?Bypass: without gain, for MM cartridges
?2??(0.6??7?applicable)?gain 29?B
?40??(7??40? applicable)?gain 23?B
Frequency response
10Hz?80?Hz?(-1dB)
Dimensions
240(W)×180(D)×70(H)mm
Weight:
2.8kgs
It’s a superb SUT but it is somewhat more sensitive to hum from surrounding components so you have to take more care in placing it.
Thanks. Always wondered whether it made sense getting a general SUT like this or a manufacturer specific one, i.e. MSL SUT for MSL cartridges, Ikeda for Ikeda and Ortofon for Ortofon. I have a Ortofon SPU Century, Ikeda 9GSS and Ortofon Anna that i might need boosting.
A specific brand SUT for the same brand cartridge is nothing more than marketing hype. The Air Tight SUT will accommodate any cartridge on the planet.
Reactions: howiebrou
Multiple inputs would be nice so i don't need to buy several although i don't mind if they're not extravagantly priced. The Ortofon SPU, Ikeda 9GSS are both quite low impedance cartridges. I intend to add a MSL gold/Platinum some stage in the future (although i already have the MSL SUT) which is low impedance too. I know SUTs is a bit of a minefield so just trying to shortlist some brands worth considering...or excluding ones that i should not consider might be a good place to start.
Let's take the Ortofon SPU Century for starters...any suggestions?
Reactions: jeff1225
Howiebrou,
I'm very happy with mine (frankly I'm unsure whether I've got the "reference" version, though).
Works well with Very Low Output cartridges, such SPU Century, KOETSU Platinum Generators, the IKEDA Mono and since a few days even with an EMT shellac cartridge. ;)
The “Bypass” (Direct Input) additionally allows to connect an MM cartridge to the MM RIAA Phono Stage
I admit, I have no experience with other "high-end" SUT's
Regards
Urs
If one has multiple carts, it’s very convenient to have more than one impedance input setting. For performance and cost I very much like the EAR MC-4, though inputs are not switchable. One reason I use the Air Tight is its Bypass mode which makes it super convenient to use my high output SPU Mono GM MkII when I’m not playing my other SPUs.
Input Selector
? position
Frequency response
10Hz?80?Hz?(-1dB)
Dimensions
Weight:
2.8kgs
Howie,
I have this box sitting idle. If you want to try, send me your address. If you like, you buy at your price, if you don't, send it back to me ;).
Kind regards,
Tang
Howie,
Kind regards,
Tang
That is incredibly kind of you Tang. Will send you a PM.
Howiebrou,
Regards
Urs
Thanks Urs. I was not even aware that there might be more than one version. Air Tight's website seems to only have one.
I highly recommend the Emia MC Trio with silver windings. Dave can provide any combination of winding resistance you need to match with your carts.
http://myemia.com/Trio.html
I own the single silver, along with @mountainjoe and @brencho . @jjaudio has the Trio.
Thanks. Will check them out. It seems as though the world of SUTs is even more wild than cables!
Do I need a special phono cable from my SUT to phono amp with ground or can a normal pair of rca cables work just as well?
Not just any cable. This is a sensitive position. Best to have minimum length, preferably less than one meter, with low capacitance.
Thanks. Would the test to see whether this is needed be whether hum is induced?
Right now my Ikeda tonearm cable is going to the MSL SUT but i have a normal pair of rca cables going from the sut to my phono amp.
There is no hum that i can detect but from what you are saying i might get a jump in performance with a low capacitance short phono cable (presumably with ground as well)?
No that's not the test. A simple shielded silver cable can work, but the phono cable includes the ground wire with spade connectors. I eventually found that disconnecting the ground cable between the SUT and the phono worked best in my system. Hum is usually a ground potential bugaboo in the system, if your cables are shielded.
